HT setup using T24
Re: HT setup using T24
Yes I have been through this menu. The only speaker that can have cross over adjusted are the main center and surround. The sub only level and distance
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
Who has experience with the mini dsp. I see a main board, a input output connector board and an optional interface board to allow more controls via PC . What is the least I need to just do hi and low pass
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
You can't use it with your receiver to high pass. That would require the ability to insert it between the pre-amps and power amps.
I am using an external amp for the sub. The LRC and surround is being processed by the Sony. I just need to process the sub
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
You said 'The only speaker that can have cross over adjusted are the main center and surround', with no mention of the L/R. Whatever. For both low passing and EQ I'd use this:
https://www.parts-express.com/Dayton-Au ... er-230-520
It's not user friendly, because the instructions are crap. But I found other subs that use the same control app and their instructions are OK.
Punctuation to the rescue!
LOL
Punctuation matters.
Let's eat kids!
Let's eat, kids!
Let's eat, kids!
For an old guy I'm falling into bad habits.
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
Order the Parts Express Dayton Audio device, A little more than I hoped to spend but it should do the trick. 150 Canadian with tax and shipping. The shipping was as much as the unit.
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
Got the unit and the learning curve is a bit steep due to crappy instructions. But it does the trick.
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
Works well with iPad but android phone won't seem to connect.
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
https://hometheaterhifi.com/reviews/aud ... ontroller/
This review and instructions are quite good compared to the instructions with the unit.
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
I ended up using the instructions for the Earthquake Sound MiniMe DSP, which uses the same software.
