T60 Build, problem with braces (solved)
Re: T60 Build, problem with braces
I could make them like this, what do you think?
They are braces, use another type of glue.
Or make the braces without joints at all, from a sheet of ply.
My concern would be, if it’s not holding the braces together, it’s probably not holding the panels to the side either. So you need to find that out...
Hi, the other panels are glued ok, no problem at all, i't might be that is too little surface area so they snap easily (braces). I attach one picrue.Grant Bunter wrote: ↑Thu Jun 25, 2020 2:37 pm They are braces, use another type of glue.
I assume you are trying to save weight. Could you cut the braces using a full piece of plywood and then plunge cut the holes out with a jigsaw? Or use a hole/cup saw and make a bunch of holes?
Hi, yes I could, but I have already cutted all the pieces, and to do that I'll have to buy more plywood.
I will show pictures of the finished braces soon.
Hi Bill, I have a question, with how many boxes, I will achieve the flattest response?, are the T60 tuned to 1/4 W 25Hz?
Best regards
Best regards
Outdoors it takes six to go flat to 26Hz. Indoors it takes as few as two.
Thank you, I will build 6 27" WideBill Fitzmaurice wrote: ↑Thu Jul 02, 2020 5:13 pm Outdoors it takes six to go flat to 26Hz. Indoors it takes as few as two.
Just for clarification... will single 12" loaded slims produce those results, or are we talking 6 cabs in the 27+" width range?Bill Fitzmaurice wrote: ↑Thu Jul 02, 2020 5:13 pm Outdoors it takes six to go flat to 26Hz. Indoors it takes as few as two.
That applies to 1x15 or 2x12.
Whould it be better to stack them on a horizontal line, or 3X2 stack?
