W10 in progress
Re: W10 in progress
Its really not THAT spendy... only like 1.5 times the price of normal black paint.
Re: W10 in progress
Thank you, so I should have plenty left for future builds, do you thin it at all and did you use a roller or sprayed it on?racertomtom wrote: Yes, I put 2 coats on 2-T39s, 2- OT12s and 4 WH8s. I have 1/3 gallon left.
- racertomtom
Re: W10 in progress
I rolled it on without thinning.TheCesar wrote:Thank you, so I should have plenty left for future builds, do you thin it at all and did you use a roller or sprayed it on?racertomtom wrote: Yes, I put 2 coats on 2-T39s, 2- OT12s and 4 WH8s. I have 1/3 gallon left.
4 - WH8
2 - T39 24" Lab12
2 - OT12 3012HO/NSD2005
2 - T39 24" Lab12
Re: W10 in progress
Thank you!racertomtom wrote:I rolled it on without thinning.TheCesar wrote:Thank you, so I should have plenty left for future builds, do you thin it at all and did you use a roller or sprayed it on?racertomtom wrote: Yes, I put 2 coats on 2-T39s, 2- OT12s and 4 WH8s. I have 1/3 gallon left.
Re: W10 in progress
sine143 wrote:Its really not THAT spendy... only like 1.5 times the price of normal black paint.
For some reason in mi mind even paint is spendy,
Re: W10 in progress
well.. tbh I'm in the same boat... but somethings gotta go on there... and if I compare it to what I would spend on flat black... it makes me feel less
Re: W10 in progress
True, unless, you paint it with cheap .99 black spray can paintsine143 wrote:well.. tbh I'm in the same boat... but somethings gotta go on there... and if I compare it to what I would spend on flat black... it makes me feel less
Re: W10 in progress
HELPPP!
I finished the horns but when I was trimming the bottom of one of them I went about an 8th overboard, would I still be able to use the horn? is there any solution other than re building the whole horn?
Re: W10 in progress
Fill it up/rebuild the thickness with succesive applications of bondo if you think that will suffice, or add a nice thin piece of ply and PL it on, let it set, and re trim...
Re: W10 in progress
Bondo should work after fiting it in its not to bad, my only concern with bondo is what ive read about duratex. Thanks for your quick reply grant!
- Scott Brochu
Re: W10 in progress
an 1/8" is not bad when you are cutting the horn to fit inside the cabinet box.
When you install the horn inside the box put a large bead of PL on that side.
Drumming is a way of life.
ME LIKE TO HIT THINGS!
Re: W10 in progress
+1, especially if you use some temporary screws to hold the horn in place with the gap halved to either edge.Scott Brochu wrote:an 1/8" is not bad when you are cutting the horn to fit inside the cabinet box.
Re: W10 in progress
Thank you, I was really mad at my self for making this stupid mistake, this takes some stress out of my life.Bill Fitzmaurice wrote:+1, especially if you use some temporary screws to hold the horn in place with the gap halved to either edge.Scott Brochu wrote:an 1/8" is not bad when you are cutting the horn to fit inside the cabinet box.
I was sure that I would find a solution here on the forum.
Again Thanks to all of you for your help!
Re: W10 in progress
Hello guys,
I have a quick question ive read the plans several times but im not sure if im just missing it or it does not have it in there, i need the steps to break the speakers, i was wondering if there is a tread already about it or a link that can walk me on how to break them.
