DIY stage
James R
Re: DIY stage
#16 Post by James R »
Outdoor carpet, or something with traction
4 x T48 24.5" 3015LF
8 x 112 Otops
NEXT 2 x DR280's
Re: DIY stage
#17 Post by Bruce Weldy »
James R wrote:Outdoor carpet, or something with traction
+1
mattaudio
Re: DIY stage
#18 Post by mattaudio »
I was at HD last night picking up sheetrock and other paneling. 7/16 OSB sure is cheap, even compared to underlayment. Maybe it would work for 4x8 stage panels with studs underneath at 16" or maybe 12" on center.
gdougherty
Re: DIY stage
#19 Post by gdougherty »
mattaudio wrote:I was at HD last night picking up sheetrock and other paneling. 7/16 OSB sure is cheap, even compared to underlayment. Maybe it would work for 4x8 stage panels with studs underneath at 16" or maybe 12" on center.
The stage I described was built out of OSB.
sine143
Re: DIY stage
#20 Post by sine143 »
OSB plus Shipping pallets (find at the back of your least favorite supermarket). + a ton of cinderblocks.
mattaudio
Re: DIY stage
#21 Post by mattaudio »
What's the advantage of using pallets underneath instead of a 2x4 frame? Easier to build?
guitarkeys.com
Re: DIY stage
#22 Post by guitarkeys.com »
Matt,
Drop me a PM and I can send you some plans for a portable stage. I did 3 x 6 panels as that is a good size for a one man setup. Stage height is up to you. I have 18", 32", and 48" heights and all have been extremely solid.
Jamie
Fayetteville, AR
sine143
Re: DIY stage
#23 Post by sine143 »
mattaudio wrote:What's the advantage of using pallets underneath instead of a 2x4 frame? Easier to build?
cost effectivness, ease of breakdown (burn it etc). allows you to make 1 time stages without worrying about hauling or purchasing materials.
