DIY stage
Re: DIY stage
Outdoor carpet, or something with traction
" Everyone Has a Photographic Memory, Just Not Everyone Has Film In The Camera"
4 x T48 24.5" 3015LF
8 x 112 Otops
NEXT 2 x DR280's
8 x 112 Otops
NEXT 2 x DR280's
Re: DIY stage
+1James R wrote:Outdoor carpet, or something with traction
Re: DIY stage
I was at HD last night picking up sheetrock and other paneling. 7/16 OSB sure is cheap, even compared to underlayment. Maybe it would work for 4x8 stage panels with studs underneath at 16" or maybe 12" on center.
gdougherty
Re: DIY stage
The stage I described was built out of OSB.mattaudio wrote:I was at HD last night picking up sheetrock and other paneling. 7/16 OSB sure is cheap, even compared to underlayment. Maybe it would work for 4x8 stage panels with studs underneath at 16" or maybe 12" on center.
Re: DIY stage
OSB plus Shipping pallets (find at the back of your least favorite supermarket). + a ton of cinderblocks.
4x Otop12 d2512 loaded
2x AT (1 mcm, 1 gto 804)
1x bastard XF208
1x bastard XF208
Re: DIY stage
What's the advantage of using pallets underneath instead of a 2x4 frame? Easier to build?
guitarkeys.com
Re: DIY stage
Matt,
Drop me a PM and I can send you some plans for a portable stage. I did 3 x 6 panels as that is a good size for a one man setup. Stage height is up to you. I have 18", 32", and 48" heights and all have been extremely solid.
Jamie
Fayetteville, AR
In Pursuit Of Audio Perfection
"A Bad Mix is Bad at Any Volume"
Fayetteville, AR
Re: DIY stage
cost effectivness, ease of breakdown (burn it etc). allows you to make 1 time stages without worrying about hauling or purchasing materials.mattaudio wrote:What's the advantage of using pallets underneath instead of a 2x4 frame? Easier to build?
1x bastard XF208
1x bastard XF208
