Introducing SPL Chart
DaveK
Re: Introducing SPL Chart
#136 Post by DaveK »
sine143 wrote:you guys must have all missed the thread where I was talking about using W10s as dedicated tops.... :noob:
Saw it. I suspect Harley did, too, and that's what got us thinking about the subject. I can't remember if you included the comparison chart. If you did, I apologize for the duplication.
sine143
#137 Post by sine143 »
I'm fairly sure I did, but I dont remember. I believe the general consensus was that the DR280 > W10 as a top, with similar box size. The w10 takes a lot more eq to act as a top as well.
DaveK
#138 Post by DaveK »
sine143 wrote:I'm fairly sure I did, but I dont remember. I believe the general consensus was that the DR280 > W10 as a top, with similar box size. The w10 takes a lot more eq to act as a top as well.
The DR should be a better box since it has a longer horn. J112 and W10 are a much closer comparison since they have a similar horn length.
subharmonic
#139 Post by subharmonic »
Chris
Can you add a THT Lab15 18" vs 24" chart? The Lab 15 is in the plans but no chart.
Thanks
Dan
I need more bass
CW Mcall
#140 Post by Chris_Allen »
subharmonic wrote:Can you add a THT Lab15 18" vs 24" chart? The Lab 15 is in the plans but no chart.
Hi Dan,
I've had a good look round but I can't find a copy of the chart to sample.
subharmonic
#141 Post by subharmonic »
Okay, thanks for trying.
I need more bass
CW Mcall
#142 Post by Bill Fitzmaurice »
subharmonic wrote:Chris
Thanks
Dan
There is no chart for a LAB 15 in a 24" THT because it's not a recommended use. LAB 15 is only specified for 18-20" widths.
subharmonic
#143 Post by subharmonic »
Bill Fitzmaurice wrote:There is no chart for a LAB 15 in a 24" THT because it's not a recommended use. LAB 15 is only specified for 18-20" widths.
Bill,
Is there a chart for the THT Lab 15 18"? It is not in my plans nor can I find it anywhere. I am not trying to :horse: , Just want to see what I am dealing with since I have a couple Lab 15s on order.
Thanks,
Dan
I need more bass
CW Mcall
#144 Post by Bill Fitzmaurice »
It's similar to the 24" but with the lower corner frequency at 28Hz instead of 25Hz. In a 30" width the Fc is at 22Hz.
subharmonic
#145 Post by subharmonic »
Bill Fitzmaurice wrote:It's similar to the 24" but with the lower corner frequency at 28Hz instead of 25Hz.
Thanks for the reply Bill. What driver loaded 24" are you referring to? I found charts on the Lab 12 and Tempest 15, from the charts I am assuming it is the Admire 15
Bill Fitzmaurice wrote:In a 30" width the Fc is at 22Hz.
I am not sure what this means. Can anyone help me understand this? Thanks
I need more bass
CW Mcall
ewetho
#146 Post by ewetho »
Was lookin at stuff on here and accidentally posted
subharmonic
#147 Post by subharmonic »
Anybody? :feedback:
I need more bass
CW Mcall
#148 Post by Bill Fitzmaurice »
The corner frequency is just what the term implies, the frequency where response falls off and the chart trace turns a corner.
Mikey
#149 Post by Mikey »
Chris, could you please add the 3012LF T30 in 16", 27", and 30" widths? They're all in the SPL Charts section.
Albert Einstein
#150 Post by Chris_Allen »
Mikey wrote:Chris, could you please add the 3012LF T30 in 16", 27", and 30" widths? They're all in the SPL Charts section.
Sure:
Code: Select all
[spl]T30W16D3012LF,T30W27D3012LF,T30W27D3012LFX2,T30W30D3012LF&dbmin=80&dbmax=110&fmax=200[/spl]
Code: Select all
[spl]T30W16D3012LF,T30W16D2010& dbmin=80&dbmax=110&fmax=200&dbmark=89.5,92&fmark=35,50[/spl]
Checked Bill's charts and the 2010 does provide a 2.5dB advantage between 35 and 55 Hz.
