Fill My Shop
MDW
Re: Fill My Shop
#16 Post by MDW »
Ok, Let me get straight.
A pair of these: Six foot high pro-sound version of TLAH, loaded with 8" drivers
And 1 of these: http://billfitzmaurice.net/THT.html
Tuba HT 36"
Is this correct?
Michael
Re: Fill My Shop
MDW wrote:Ok, Let me get straight.
Tuba HT 36"
Is this correct?
Michael
THT only if you need to go below 30Hz. With music, you don't.
MDW
Re: Fill My Shop
#18 Post by MDW »
I really want this setup to be for music 1st , the TV is an afterthought at best.
We jam to the music 99.9% of the time.
We also have party's/crawfish boils occasionally.
Probably going to have a superbowl party here.
With that in mind what do ya think?
Thanks again for all the advice, Michael
Re: Fill My Shop
MDW wrote:I really want this setup to be for music 1st , the TV is an afterthought at best.
T48.
SeisTres
Re: Fill My Shop
#20 Post by SeisTres »
Bill Fitzmaurice wrote:Assuming this space is very reverberant you want the highest possible set of mains. That would be TLAH Pro, which would be a lot easier build than three or four DR200 or OTop 12 to get the same height.
What about the parts express 3x5 full range driver in the SLA vertically stacked for max height? they run $1.5 in quantity. The tweeter might get expensive, but i do have 200 sitting in my closet :mrgreen:
Re: Fill My Shop
You'd need 32 of them per side to get TLAH Pro levels. That's a lot of holes to cut and a lot of drivers to wire.
MDW
Re: Fill My Shop
#22 Post by MDW »
What about LeLand's idea of 2 DR250's and 2 T48's 36" wide?
Or am I looking at 2 T48's 36" wide and 2 TLAH Pro's?
Re: Fill My Shop
MDW wrote:What about LeLand's idea of 2 DR250's and 2 T48's 36" wide?
Plenty of output, but controlling early reflections requires vertical pattern control, and it would take three DR250 per side to work as well as one six foot TLAH. Build the subs 36", if it's a permanent install no reason why not.
MDW
Re: Fill My Shop
#24 Post by MDW »
Any recommendations as to what to put in the Pro TLAH?
Or is it in the plans?
Would you mind emailing me the TLAH plans so I get a head start on ordering the stuff to get this off the ground?
Thanks again for all the support, Michael.
Next I need to talk about amps :)
BrentEvans
Re: Fill My Shop
#25 Post by BrentEvans »
withdrawn. :oops:
MDW
Re: Fill My Shop
#28 Post by MDW »
Re: Fill My Shop
#29 Post by LelandCrooks »
Protection resistor for the piezo array. http://www.speakerhardware.com/piezo_re ... ts0044.php
MDW
Re: Fill My Shop
#30 Post by MDW »
I can't swing the 8"er's right now so I PMed Leland to see what he has to build some nice TLAH's.
I also asked him for the stuff to put 2 T48's with 3015lf's.
Lets see what he comes up with :)
Michael
