The shop is 50ft X 50ft with 20ft ceiling. It's all metal so the acoustics are going to be bad.
The shop is square so placement is a concern. Should I hang them? Also they will not be moved so weight and size are not an issue.
I can go as big as we need to. It seems to me that most of the the builds are about weight and mobility. Does the fact that this will not be moved change the material choices? ie: 3/4" over 1/2"?
I can fabricate anything. I have tablesaws, drill presses, belts sanders, compound miter saws, etc... so wood is not a problem.
I even have metal capabilites, Plasma cutters, welders (mig, tig, stick), Bridgeport mill, lathes, etc...
The problem is I don't understand all the acronym's and jargon being used on here. Am I screwed?
I have not bought anything as I wanted to start with a clean slate based on suggestions from here.
Now for the wants: I want this place to ROCK. I listen to 60's, 70's 80's stuff.
Led Zepplin, Edgar Winter, Doobies, AC/DC, etc.. I like bass but I don't like boom, does that make sense?
When the drummer hits the snare I want to FEEL it.
Now I'm not saying money is no object but I have a few bucks to work with.
I just don't like buying store bought stuff, I prefer to make my own as it seems so do you
What ya got? I'm your puppet
Michael
