Wood Filler
Chris Betancourt
Wood Filler
#1 Post by Chris Betancourt »
Sanding and prep. is king. I'd say that the Elmer's wood filler is great to work with water clean-up if starts to dry put a little water in it and problem fixed and you could get it the consistency you want.
elmers woodfiller.jpg (10.9 KiB) Viewed 1473 times
These are a pair of small monitors for a client.
This wood filler is great to work with!!!
Christopher Betancourt
Authorized Builder
Puerto Rico
All running w/SAC or DL1606
On the table:
too much work!! LOL
Future:
myn
Re: Wood Filler
#2 Post by myn »
Just make sure if you choose to use Duratex as the finish that you primer it with a latex paint prior as Duratex doesn't stick well to the Elmers wood filler.
Chris Betancourt
Re: Wood Filler
#3 Post by Chris Betancourt »
Yes. There's a few things that the Duratex won't stick too like PL and some screws heads too. There should be a few more. Its a MUST to prime first, you will save a ton of Duratex and would look a heck of alot better. Very Pro Looking. :clap:
Authorized Builder
Puerto Rico
On the table:
too much work!! LOL
Future:
Scott Brochu
Re: Wood Filler
#4 Post by Scott Brochu »
myn wrote:Just make sure if you choose to use Duratex as the finish that you primer it with a latex paint prior as Duratex doesn't stick well to the Elmers wood filler.
I'll second that!
I don't use that s**t anymore because of that.
Spend the extra $$ and get good spray paint, if you go that route. :wink:
Drumming is a way of life.
ME LIKE TO HIT THINGS!
Chris Betancourt
Re: Wood Filler
#5 Post by Chris Betancourt »
Is there any primer that you guy's avoid working with? And which is your favorite
Authorized Builder
Puerto Rico
On the table:
too much work!! LOL
Future:
Scott Brochu
Re: Wood Filler
#6 Post by Scott Brochu »
maximuma wrote:Is there any primer that you guy's avoid working with? And which is your favorite
To save on Duratex I use Rustoleum brand flat black. It goes for around $4.50 (US).
I tried the cheap .99 cans Wally World sells........you get what you pay for. :roll:
phil
Re: Wood Filler
#7 Post by phil »
I'll second that!
What do you use now?
Scott Brochu
Re: Wood Filler
#8 Post by Scott Brochu »
phil wrote:
I'll second that!
I use bondo, in multiple layers depending on the finish covering I would apply to that cabinet.
But at least one good coat of primer (Rustoleum).
It works very well IMHO.
phil
Re: Wood Filler
#9 Post by phil »
I picked up a can of that and got intimidated by the hole mixing thing, lol. I also thought on the last build the duratex would fill in minor imperfections cause it seems so thick. Boy was I wrong.
I was planning this time to use the bondo and primer (and tackle my mixphobia in the process :) ), so I'm glad to hear I'm on the right track :).
Scott Brochu
Re: Wood Filler
#10 Post by Scott Brochu »
I went to a Auto Zone (car parts store) and asked if they had any without the 2 part mix. Just open the tube and go.
It cost about 10 bucks.
Israel
Re: Wood Filler
#11 Post by Israel »
Scott Brochu wrote: I use bondo.
+1 ....Cabinetry panels sometimes came with bondo...
MADE
4- OT12'S BETAII
4 T39'S 20" 3012LF LOADED
ON THE BENCH: 2 OT212
Re: Wood Filler
#12 Post by DJPhatman »
Scott Brochu wrote:I went to a Auto Zone (car parts store) and asked if they had any without the 2 part mix. Just open the tube and go.
Spot putty?
Scott Brochu
Re: Wood Filler
#13 Post by Scott Brochu »
Spot putty?
Yes, Dynatron Glazing and spot putty 1lb tube
jswingchun
Re: Wood Filler
#14 Post by jswingchun »
Spot putty?
What's the curing time on that? The body filler (bondo) that you mix cures really quickly, which is nice when you have a lot to do.
Omni 10
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
Chris Betancourt
Re: Wood Filler
#15 Post by Chris Betancourt »
I just finished priming the two monitors and I use flat black Rustoleum on these I've been using rustoleum for more than 10 years but I've Started using Duratext his year. The 2 part bondo is alot of work. Never tried the one part tube I'll give it a try.
Authorized Builder
Puerto Rico
On the table:
too much work!! LOL
Future:
