The Furman:
Does anyone have any experience with the Eaton (Heinemann) breakers for this application?
I know they need to be magnetic/high inrush, and in looking at the Furman distro it looks like they're using the J series Eatons or similar: (scroll down to page 16 on the link below for the specs)
http://www.eaton.com/ecm/groups/public/ ... 00001e.pdf
I'm thinking 3 or 4 of the JA series with "curve 2". The curve one seems like it would be better suited to audio but they don't offer a 1 curve on the J series
I already have an empty 2U rack case (steel) that I can use to house the breakers, and outlets. I can just drill the required 3 holes for each of the breakers to the front panel and wire up the busses and add a Hubbell socket and 3 or 4 Edison's on the back. I have some 50' 6/4 SJO (maybe 8/4?) with Hubbel Twist Locks on each end left over from our construction trailers that I can use.
