Getting Angles Correct with Circular Saw?
myn
#1 Post by myn »
What's everyone's technique for getting angles and length correct with a circular saw?
Assuming your saw blade is perfectly square, Can the angle indicator on the circular saw be trusted?
Sydney
Re: Getting Angles Correct with Circular Saw?
#2 Post by Sydney »
Trigonometry rules give reference to accuracy of cuts.
Tom
#3 Post by Tom »
myn wrote:Assuming your saw blade is perfectly square, Can the angle indicator on the circular saw be trusted?
Cutting square is always good, but we're not talking about cross cuts are we? We're talking about beveled edges, I think.
Even with my Cabinet saw, I'm not too worried about exact angles on most speaker cabinet parts. The PL adhesive will fill in gaps, after dry fitting and a little bit of rough sanding to improve the fit.
Build Log
-- Done, in use --
4 - Dr250/2510/Piezo
2 - OmniTop 12
2 - T48/3015LF (22 inches wide)
2 - T48/3015LF (25 inches wide)
4 - Melded array w8
? - Omni 10
myn
#4 Post by myn »
Aren't most of the angled cuts crosscuts?
pgolde
#5 Post by pgolde »
myn wrote:What's everyone's technique for getting angles and length correct with a circular saw?
I wouldn't
The sliding T-bevel is your friend
angles can be drawn on wood from protractor or speed square or other such devices
set the sliding t-bevel or angle finder to angle and use it to adjust your saw to correct angle
djohnson573
#6 Post by djohnson573 »
pgolde wrote: The sliding T-bevel is your friend
+1 Even if you use a table saw.
Dennis
Built/Own:
- 4 x Titan 39 (14"W) BP102 loaded
- 2 x TLAH
- 4 x OT12 Deltalite 2512 loaded
On Deck:
- 3 Auto Tubas
myn
#7 Post by myn »
Great info! I've got a t-bevel.
What's the technique to align the circular saw blade to the same angle as the t bevel?
djohnson573
#8 Post by djohnson573 »
myn wrote:Great info! I've got a t-bevel.
http://billfitzmaurice.net/phpBB3/viewt ... =14&t=7404
Dennis
Built/Own:
- 2 x TLAH
On Deck:
- 3 Auto Tubas
