I noticed that on John's DR250 when we went from pink noise to manually running a sweep and noting the spl at each freq. When we ran the pink noise I would calibrate the "mic" on TrueRTA by inputting the spl reading at the meter. Looking back at the RTA plots the overall SPL would be in the 100's (light blue bar on left of screen) but no single frequrency would get into that range on the actual plot... I just assumed a sum of all the frequencies added up to the toal output. (SPL)Bill Fitzmaurice wrote:When measuring with a noise source it will come in 6 to 12dB lower than with a swept sine wave, depending on the resolution used.
What resolution would you recommend for future reference?
