How much Duratex?
howdy_strangr
How much Duratex?
#1 Post by howdy_strangr »
For (4) T-36's 30"
Rolling?
Spraying?
Is there a difference in amount needed?
#2 Post by DJPhatman »
Depending on your personal preference, and abilities. I found rolling High-Build DuraTex was much easier than spraying, and I liked the results.
That said, I would say get 2 gallons. One should be enough, but get an extra for mistakes, waste, the rest of the cabinets you are going to build! :shock: :twisted:
YMMV, Batteries Not Included, Don't Drink and Drive, :roll:
David Carter
#3 Post by David Carter »
I don't know how much it would take for your cabs, but I have rolled both the high-build and the roller-grade stuff, and I got better results from the roller grade. I have also spoken with the folks at Acrytech, and they told me that if you're rolling, you should use roller grade.
Dave
- 2 x Titan 39 (BP102 - 14"W)
gdougherty
#4 Post by gdougherty »
David Carter wrote:I don't know how much it would take for your cabs, but I have rolled both the high-build and the roller-grade stuff, and I got better results from the roller grade. I have also spoken with the folks at Acrytech, and they told me that if you're rolling, you should use roller grade.
Yeah, the note that rolled on the high-build would leave a sandpaper like texture didn't sound appealing to me. Unless I had an itch on my back..
