DIY cables
MikeHunt77
#16 Post by MikeHunt77 »
over/under cable coiling is good as it doesn't add twists too the cable. :)
"You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer" - Frank Zappa
mangomanj
#17 Post by mangomanj »
+5
After you've mastered the over/under method, try this:
Lay the coiled cable on the ground. Grab the cable end that is on top. Now pull it! It will unravel without knotting up! Try doing that with cable that's been coiled over/over.
Jason
"Choose this day whom you will serve..." - AltaredLife
gdougherty
#18 Post by gdougherty »
mangomanj wrote:+5
Jason
Just make sure you always grab the right end and that one end doesn't get tucked through the loop either. I use velcro one-wrap straps, strap them tightly and always start from the male end where it'll plug into the snake so I can toss it towards the instrument or position I want the cable to end up. It also seems best if you always toss with an eye towards unspooling the entire cable, otherwise it often tangles and knots along the way with short tosses o longer cables. That's also why I carry a good assortment of 10ft, 20ft and 30ft cable.
nola50
#19 Post by nola50 »
For excellent cable work for instruments, pedal boards, speakers, or any kind of custom work, I call or email Butch
http://www.bayoucables.com/
