help cutting metal grill
				bubblersound
I bought 22x30" metal grills and wanted to know how do you guys cut them to specific sizes.  I'm trying to get 2 grills (21x14" each) from this for a pair of OT12's.  What tools do I need to get a nice cut?  Thanks.
				bgavin
I use a metal cutting blade in a circular saw.  Hand dressing of the sharp edge is mandatory after making the cut.
If you have access to a bending brake, that puts the sharp edge inside the cab and out of harm's way.
						I use a jigsaw with metal blade. Just make sure its clamped down so it doesn't jump everywhere.
									www.cdphoto.co.uk
- wedding photography in the Midlands UK
				mudbwetdirt
Too bad you are so far away my 52" shear would make a nice cut. Hmm maybe I'm the one thats so far away I'm in the the middle of nowhere. I even have a pan and box blade for my 48" brake but I wonder what the shipping to nowhere and back would be.
									My Name Is Mud B. Wetdirt it's been Mud for as long as I can remember. She has other names for me but I can't use them on family forums.
						There's a bit of info and the advice to use an agle grinder on her http://www.speakergrills.co.uk/
						- Frankenspeakers
I've used an angle grinder before both the makita and the cheap chineez air ones, 3" wheel and look out for the sparks! I reccommend goggles and a full face shield.
									There is no technical problem  however complex, that cannot be solved or finessed by a direct application of brute strength and ignorance.
