2x THTLP build after a 10 year hiatus
shawn_g
#1 Post by shawn_g »
It's hard to believe it's been nearly 10 years since my last build! I built out our unfinished upstairs/attic and have been using a pair of T39's (from my signature) as makeshift home theater subs. They sound great, but they're obviously not designed for HT use and drop off below 35hz pretty quickly. When I framed the area behind my TV, I specifically made enough room for two THTLP's to go there and the time has come to build said THTLP's. Once these are built, the T39's (cabs only) will probably be up for sale if anyone is interested (SE Ohio).
I'm going with 23.5" wide panels to maximize plywood use (1/2" Arauco) and am hoping to build both cabs with 5 sheets assuming I don't make any really dumb mistakes. So odds are I'll be purchasing a 6th sheet :lol:
I'm reusing the Lab 12's from the T39's. I'm going with the "extended surround drivers" option in the plans to potentially use 15's in the future so I'd only need to build a new mounting panel instead of a whole new cab, but I'm fairly confident the 12's will be plenty.
So first the space in question. The subs will go behind the TV and you can barely see the edge of a T39. For reference, the TV is 85".
Getting started on first cab:
Using my MPCNC for the 2/6 braces. You can see failed attempt #1 in the top of the frame:
Making some good progress:
CNC to cut out router templates for the curved mouth braces:
That's all the progress for now. I'm hoping to get them finished within the next few weeks. They'll be finished in Duratex. :hyper:
Re: 2x THTLP build after a 10 year hiatus
#2 Post by Tom Smit »
Good progress so far!
88h88
#3 Post by 88h88 »
Are you sure the structural integrity of the room will be able to withstand 2 of them flexing way down in the hz? :lol:
shawn_g
#4 Post by shawn_g »
Tom Smit wrote: Thu Mar 05, 2026 10:41 pm Good progress so far!
So far, so good!
88h88 wrote: Fri Mar 06, 2026 5:25 am Are you sure the structural integrity of the room will be able to withstand 2 of them flexing way down in the hz? :lol:
I sure hope so! lol
I got panel 9 and the 4/9 braces installed on both cabs last night. I forgot how time consuming the braces can be!
Joman116
#5 Post by Joman116 »
shawn_g wrote: Fri Mar 06, 2026 7:13 am
So far, so good!
I sure hope so! lol
Looking good. Where are you finding arauco acx?
QSC 1804 Amp
Keryn O'Shea
#6 Post by Keryn O'Shea »
shawn_g wrote: Thu Mar 05, 2026 9:58 am..I specifically made enough room for two THTLP's to go there and the time has come to build said THTLP's..
:clap:
I really enjoy seeing these and the T60s come together
They'll definitely test it, possibly some dust in the air for the first couple of digs.
shawn_g wrote: Thu Mar 05, 2026 9:58 am Using my MPCNC for the 2/6 braces.
I find this gadget very interesting, thanks for sharing.
In regards to finish in the mouth area, are you using Duratex & painting before the side is attached?
