Solid/Joined wood for cabs?
RunTheOtherWay
#1 Post by RunTheOtherWay »
I have a line on some reclaimed wood that for the sake of discussion I can get cut down to 3/4" x 8" x 24" and I might want to cut those down further to 3/4" x 2" x 24" and join them to make whatever depth I want. I've made an XF210 out of 3/4" plywood and am very happy with it; the split baffle is 1/2" solid joined pine that I already had on hand and had had it for so long that I knew it would be as dried out as it could be and it was still dead flat.
I keep reading in audiophile forums that solid wood is to be avoided for speaker cabinets because it's more resonant than plywood. My question is, is it a bad idea to use solid/joined wood in the XF guitar cabs or the Fitzmaurice-design fullrange or sub cabs? If not, would it help to bond bitumen or other heavy and stable material around the inside?
Thanks!
DaveMacKay
Re: Solid/Joined wood for cabs?
#2 Post by DaveMacKay »
Avoid solid wood. Go with baltic birch, which is superior. Even MDF (shudder) would be preferable to solid wood.
#3 Post by Bill Fitzmaurice »
!. Stop reading audiophile forums.
2. Solid wood isn't more resonant than plywood.
3. Solid wood is OK so long as the maximum width used is eight inches, with no jointing.
4. There's no use for bitumen in speakers, no matter what audiophile forums say. :conf:
Chris47240
#4 Post by Chris47240 »
Hi,
Regarding solid wood, I was considering using maple, walnut or other hardwood for the carcass. Is one hardwood better than another for its acoustical properties?
Also, the cabinet depth of the XF 212 is greater than the 8 inches mentioned above so 2 boards would need to be joined to get the proper width, correct?
Thanks in advance
KentWhitten
#5 Post by KentWhitten »
Don't use solid wood. Use Baltic Birch
#6 Post by Bruce Weldy »
Chris47240 wrote: Wed Oct 08, 2025 10:03 pm Hi,
Thanks in advance
In an open-backed cab, you can do whatever you want. If you are going closed-backed, then there is more internal pressure, so stick with Baltic Birch. I built an XF210. An XF212 out of 3/4" hardwood is gonna' be heavy as hell.
Chris47240
#7 Post by Chris47240 »
Hi Bill Fitzmaurice,
What are your thoughts?
#8 Post by Bill Fitzmaurice »
I would not use solid wood.
#9 Post by Seth »
Veneer over ply is a solid option if you want the wood look
(intentional pun)
