Navigator Jack 10L Build
Re: Navigator Jack 10L Build
The front wave peak output is at 300 Hz, the port peak output is at 40 Hz, the two combine to create the output between those peaks, while port output rolls off below 40 Hz.
AndrewMoore
Thanks Bill.
Last step is to make the plexi BFM designers plate for authenticity.
That and maybe sew up a canvass rain cover for travel
AndrewMoore
happy thanksgiving all. designer plate installed
