OTop8 dispersion angle and Bi-amping
Keryn O'Shea
Re: OTop8 dispersion angle and Bi-amping
#61 Post by Keryn O'Shea »
Thanks for the kind words Lads!
Seth wrote: Wed May 21, 2025 9:58 am Which amp/s did you run it all on?
A CVR2004 for subs & mids, and a 2x800w amp l built with Wondom modules & a 60v DC power source for HF.
https://store.sure-electronics.com/product/638
Further feedback from neighbours two properties up, felt Astrix through their concrete floor, and others 1/8 mile away (the system was facing them) couldn't hear their TV inside the house :D
Is there any sense in spiralling the array for the nutters who want the be right up close to the stage, this for example, would be the LH side
Keryn O'Shea
#62 Post by Keryn O'Shea »
And Seth,
This one is following your lead...
This is how l feel when thinking about, working on, looking at or listening to Bf cabs.
And also when cruising the forum seeing what you guys are up to :D
#63 Post by Bill Fitzmaurice »
Yes, you can spiral the array. For the best result the mouths of the HF horns should be in a vertical line. That will minimize any comb filtering of the highs. The mouths of the low frequency sections need not be on a vertical line as the wavelengths they pass are too long to require it.
#64 Post by Seth »
Keryn O'Shea wrote: Thu May 22, 2025 4:25 am And Seth,
It's darn near like meeting you in person, putting a face to the name.
Thanks for that, Keryn.
As far as the subs go, it won't really matter where they're aimed. The dispersion angle/pattern of those frequencies are 360º for a stack that size. You could aim them at the sky, at the ground, toward the audience, away from the audience... won't matter much at all outdoors. Indoor placement though, that's where placement and orientation can make a huge difference.
Keryn O'Shea
#65 Post by Keryn O'Shea »
Bill Fitzmaurice wrote: Thu May 22, 2025 6:49 am Yes, you can spiral the array. For the best result the mouths of the HF horns should be in a vertical line. That will minimize any comb filtering of the highs. The mouths of the low frequency sections need not be on a vertical line as the wavelengths they pass are too long to require it.
Understood 👍
Seth wrote: Wed May 28, 2025 1:10 am You could aim them at the sky, at the ground, toward the audience, away from the audience... won't matter much at all outdoors.
If the T48s were to be setup outdoors in a line with the horn mouths towards the top..
There'd be no noticeable difference? This wouldn't look as appealing, but is easier setup as they'll be trucked out of the trailer upside down
#66 Post by Bill Fitzmaurice »
No measurable difference either, so long as the bottom of the cab is less than 1/4 wavelength from the ground. At 100Hz that's 85 Cm.
Keryn O'Shea
#67 Post by Keryn O'Shea »
More great news, thanks mate :)
#68 Post by Bruce Weldy »
Bill Fitzmaurice wrote: Sat Jun 07, 2025 4:01 pm No measurable difference either, so long as the bottom of the cab is less than 1/4 wavelength from the ground. At 100Hz that's 85 Cm.
But, won't gravity make all the sound fall to the bottom of the cab?
:mrgreen:
#69 Post by Bill Fitzmaurice »
An audiophool would say so. :roll:
Keryn O'Shea
#70 Post by Keryn O'Shea »
Bill Fitzmaurice wrote: Thu Jan 23, 2025 4:22 pm Black hot melt glue.
I finally got around to doing this, and it turned out much better than l thought! Great tip there, cheers Bill :)
#71 Post by Tom Smit »
:clap:
Keryn O'Shea
#72 Post by Keryn O'Shea »
This Saturday the 16th, this system will be running at a friends farm in Kalbar QLD, 1 hour South West of Brisbane, PM me if you're keen to have a listen.
T_Gowan
#73 Post by T_Gowan »
Would love to but don't think I can make it from Canada by then lol.
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
#74 Post by Seth »
Thanks for the invite. I'm out too.
#75 Post by Tom Smit »
Aw, shoot! Our band has a gig that day.
