Hello there lads,
Can anyone vouch for this driver..?
https://www.ebay.com.au/itm/25672366411 ... R-KQvorrZA
Should I grab it?
Prehistoric Deltalite 2512
Keryn O'Shea
Re: Prehistoric Deltalite 2512
Xmax is only 2.9mm.
Wow....I've never even seen one of those. Mounting depth might be a prolem depending on the cab.Keryn O'Shea wrote: ↑Sat Nov 23, 2024 5:57 am Hello there lads,
Should I grab it?
Those were first generation neos, and were only around for a couple of years before they were replaced by the Deltalite II.
Keryn O'Shea
Yes, a tad on the weak side for a 12.
l was thinking a J12L to replace the single SLAP we use for guitar at home, l don't have those plans though.Bruce Weldy wrote: ↑Sat Nov 23, 2024 8:19 am Wow....I've never even seen one of those. Mounting depth might be a prolem depending on the cab.
Do you know which era they were in made Bill?
Roughly 2003-2006.
Keryn O'Shea
Oh ok, not that long ago then.
I'll probably bid as l can't seem to pass up anything with Eminence written on it which l could possibly use, thank you for the responses gentlemen.
