Prehistoric Deltalite 2512
Keryn O'Shea
#1 Post by Keryn O'Shea »
Hello there lads,
Can anyone vouch for this driver..?
https://www.ebay.com.au/itm/25672366411 ... R-KQvorrZA
Should I grab it?
AT8 14", AT10 19", T30 28" LAB12, T48 36", THT 20", SLA 4x3"/4x4", CArray 6x4", TLAH, TLAP, J10 FA, J12 FA, OT8 CD, OT12 FA, OT15 CD, SLAP 2x6"/4x6", WH6 PA, WH8 MA, WH10 CD, DR280 MA, XF210.
Re: Prehistoric Deltalite 2512
#2 Post by Bill Fitzmaurice »
Xmax is only 2.9mm.
#3 Post by Bruce Weldy »
Keryn O'Shea wrote: Sat Nov 23, 2024 5:57 am Hello there lads,
Should I grab it?
Wow....I've never even seen one of those. Mounting depth might be a prolem depending on the cab.
#4 Post by Bill Fitzmaurice »
Those were first generation neos, and were only around for a couple of years before they were replaced by the Deltalite II.
Keryn O'Shea
#5 Post by Keryn O'Shea »
Bill Fitzmaurice wrote: Sat Nov 23, 2024 8:09 am Xmax is only 2.9mm.
Yes, a tad on the weak side for a 12.
Bruce Weldy wrote: Sat Nov 23, 2024 8:19 am Wow....I've never even seen one of those. Mounting depth might be a prolem depending on the cab.
l was thinking a J12L to replace the single SLAP we use for guitar at home, l don't have those plans though.
Bill Fitzmaurice wrote: Sat Nov 23, 2024 9:18 am Those were first generation neos..
Do you know which era they were in made Bill?
#6 Post by Bill Fitzmaurice »
Roughly 2003-2006.
Keryn O'Shea
#7 Post by Keryn O'Shea »
Oh ok, not that long ago then.
I'll probably bid as l can't seem to pass up anything with Eminence written on it which l could possibly use, thank you for the responses gentlemen.
