I don't check the for sale section often and new posts to this section do not show up as unread active threads. Please PM any inquiries and offers.
All this stuff's gotta go sooner or later. I'm giving you guys here first dibs. Come January, I'll list everything on Craigslist, offer up, FB marketplace, and Ebay.
Gonna list all the non amplifier hardware I have to sell in different posts to this thread, so remember to scroll down to see everything I have to offer. (that sounds bad)
I'd like to sell these together as a package: $1750 (will consider separating in February '25)
- Rack mount Midas M32C digital mixer with 2 expansion cards, USB expansion card for streaming 32 channels in/out of a computer, and the X-Live dual SD card recording expansion card) I'll have to look, I may have the original packaging for the M32C.
- Rack mount Midas DN4816-O 16 channel xlr output Interface. This unit is in it's original box which has been opened to verify contents. The unit itself is still in the factory sealed (taped) plastic bag. Never removed from bag, never plugged in, never racked. Essentially brand new in an opened box.
-Behringer SD16 I/O Stage box including the matching protective Gator Bag. I sold a rackable 32 input unit and bought this one instead. For the types of gigs I do, having a small stage box on stage is just easier than having to run all cabling offstage to the rack. Less pack space and less weight overall. I bought this one, used it once in the garage while testing something else, and unfortunately haven't had the opportunity to use it since then. Essentially brand new and flawless. The Gator bag even still has it's tags attached and in good shape.
In purchasing components for my Gig Rig, one of the most important desires was to keep it as compact and as easy to stow, transport, and deploy as possible. This system provides 16 inputs (upgradeable to 32 with the addition of another stage box) and 16 outputs with all the same functionality of a full size 32 channel console, yet it only takes up only 2RU and a small over shoulder tote bag. Rack the two rackable units with your amplifiers and when you get to the gig all you have to do is put the stage box on stage (I'n the past and a different stage box (XR18), I've put a yellow sticky note instructing the musicians which input to use and let them set them selves up) and run the appropriate CAT cable from the stage box to the amp rack, which could be up to 300 feet away.
With one of the 8 channel amplifiers I have for sale in another thread, you'd utilize only four RU and be able to have enough inputs for a fully mic'd drum set, Bass, 2 guitars, keys, 4 vocal mics, and still be able to mic a 3 piece brass section. You'd have enough busses AND outputs for two independent fully pan-able main outputs, a subs on aux output, four independent stage monitor mixes, still have enough busses and outputs left for four independent stereo IEM mixes and outputs, and even have one spare output left unused. You'd have enough DSP power built into the amplifier to fully sculpt and customize every single stage monitor mix, each top, and the subwoofer independently and enough amplifier channels and power to run it all in a small to medium venue... And it would all fit nicely in a handy rolling 4RU case and a small over shoulder bag. Both could easily fit in the passenger seat of a car.
Get to the venue, toss the bag on your shoulder, and effortlessly wheel in a 4RU roller rack inside. Go grab your speakers and set them up. Connect 7 speaker wires, 2 power wires, and the CAT cable and you're ready to sound check (assuming the band members set them selves up). The above used with a pair of DR200's, a single T39/48, and four WH6/8's would match up quite well for a small to medium venue. Larger venue's? Double up the DR's, add second roller rack with enough DSP and amplifier to power 3 more subs, and handily take care of nearly any venue, indoors or out, short of the Main Stage at the State Fair. Two small manageable roller racks and a hand bag.
Fully functional and capable while hitting my goal of being compact, easy to stow, transport, and deploy.
Those two ribbon cables just barely visible above the unit are SD card extensions, so SD cards can be swapped easily from the front of the unit and not have to go into the back of the amp rack to access them. These extensions will be included with the M32C.
(SOLD) Digital Stuff
dbx Driverack Venu 360
Package deal: dbx DriveRack VENU360 and dbx RTA-M Driverack Series Reference Microphone - $1000
I ordered the 360 from Amazon 10 months ago, Dec 31, 2023 and the microphone 5 days later. I tinkered with them for a week, packed 'em back up, and they've been on the shelf ever since. Never racked and no scratches.
The only reason I'd recommend getting the VENU360 over their PA2 or 260 models is, the PA2 and 260 models can not be used when utilizing a Subs On Aux system configuration. Which is why I went with the VENU360. I wanted the option to set my system up with Subs on Aux. Otherwise, a PA2 would have done everything else I needed at nearly half the price.
Essentially new and 80% of the actually new price.
DriveRack PA
DriveRack PA - $100
Used and shows a little wear and tear and the usual evidence of being racked. Works perfectly.
Klark Teknik DM8008
Klark Teknik DM8008 - $300
This is an 8 channel output box that used the ULTRANET functionality of Midas/Behringer m18/XR18 and m32/X32 products as well as some Klark Teknik products.
I bought this unit for my IEM rig. One standard network cable connected between this unit and the ULTRANET port on compatible products is all that's needed to get 8 channels output channels. It could be used for many situations, but I used it to feed 4 IEM transmitters in Stereo.
It has little to no use, has been racked, and my show light scratches and other evidence of being racked. I haven't pulled it out of the rack yet to see. I do have the original packaging for this unit.
I'm currently listing this item separately. However, I think I may reassemble the IEM rack and sell it as a package deal. Open to offers until that point.
In the pic below, one standard network CAT cable connects it to the M32C just above and it's supplying 8 individual outputs into 8 individual inputs of an 8 channel amplifier.
Klark Teknic DF1000 Feedback Suppressor
Klark Teknik DF1000 feedback suppressor - $80
Self explanatory. Stand alone feedback suppressor. Used for one gig. I needed two more channels of automatic feedback suppression and didn't want to buy a whole DriveRack's worth of functionality.
Currently racked, but will ship in it's original packaging.
Roller Racks etc
I guess I'll list these here too.
- 3x full 19" depth 4RU Gator brand rolling rack cases - $130each obo
Two of them are their newer, larger design and one is an older, smaller dimension case design with the same rack depth. Both designs share identical interlocking features and stack together as you'd expect them to. Personally, I wish they would have stuck with the smaller design. I prefer handling and stowing the more compact version.
- Gator Cases Portable 4U Rack Bag with 14" Rackable Depth - $80 obo
This is the rack that I used for my IEM rig. A rig that's light enough to just throw over a shoulder when you need it, or leave it behind altogether for gig's that don't require it. I'll probably reassemble and sell the IEM rig as a package deal. In the mean time if you want this for whatever suits you, shoot me an offer!
I absolutely love the mobility and versatility of using multiple 4RU cases compared to filing all the gear you may possibly need for any gig into a 20RU rack and moving that sucker around. You guys that have larger racks know, a venue with stairs is, in most cases, a no-go. Bunch of 4RU cases and the ability to easily leave behind unneeded gear and just bring enough rig for the gig? Up a flight or two of stairs? No problem! (But, still charge an additional premium anyway)
