J15 Build
Keryn O'Shea
Re: J15 Build
#16 Post by Keryn O'Shea »
Clef's of Bass wrote: Sun May 19, 2024 6:12 pm I'm back for another J15 build
Flawless craftsmanship as per usual mate 👍
Bruce Weldy wrote: Tue Jun 04, 2024 8:51 pm Love that BB ply.....
After over ten years of building, l finally picked up 1/4" BB for a pair of J10Ls, really looking forward to not dealing with warp & voids as you describe Bruce
Bruce Weldy wrote: Tue Jun 04, 2024 8:51 pm ..Too bad we always end up covering it up.
Has anyone ever used a clear finish on the Pro cabs for an install?
Clef's of Bass
Re: J15 Build
#17 Post by Clef's of Bass »
Keryn O'Shea wrote: Wed Jun 05, 2024 6:14 pm
Thanks dude. It's going together pretty good.💪
Glued in some foam before bonding the side, while I had access to it.
Clef's of Bass
Re: J15 Build
#18 Post by Clef's of Bass »
Now we're talking!
Clef's of Bass
Re: J15 Build
#19 Post by Clef's of Bass »
Almost done with the glue ups.
Clef's of Bass
Re: J15 Build
#20 Post by Clef's of Bass »
Flange.
Really pleased with how tight these glue joints are turning out.
Scott Brochu
Re: J15 Build
#21 Post by Scott Brochu »
:clap: Looking sharp :clap:
Drumming is a way of life.
ME LIKE TO HIT THINGS!
Clef's of Bass
Re: J15 Build
#22 Post by Clef's of Bass »
Scott Brochu wrote: Tue Jun 18, 2024 10:39 am :clap: Looking sharp :clap:
Thanks Scott, these J15's will be gigging cabs and will be hanging around for awhile so they'll need to look good :hyper:
Progress is slow, I have a few different projects around the house going on at the same time. :bash:
At second glance, the plug extensions look like a stack of pancakes 🥞. 🤤
Re: J15 Build
#23 Post by Tom Smit »
Progress may be slow, but, it is still....progress. :clap:
Clef's of Bass
Re: J15 Build
#24 Post by Clef's of Bass »
Tom Smit wrote: Tue Jun 18, 2024 9:43 pm Progress may be slow, but, it is still....progress. :clap:
getting closer to finishing
Great progress today. Glued in the side handle supports, routed for the side handles, and drilled out the rear panel screw flange. Had and Idea about the speakon connecters. I really don't like the connector dish look, so I chopped up the dish and will use it as a washer for the bolts.
Clef's of Bass
Re: J15 Build
#25 Post by Clef's of Bass »
Alright!
Back and sides done. Now it's time to finish the exterior. Duratex time :hyper:
Clef's of Bass
Re: J15 Build
#26 Post by Clef's of Bass »
Finally got some dye, poly, and Duratex on it. Almost done with the outside.
Also, made scrap bin for some shop organization (long overdue).
Re: J15 Build
#27 Post by Tom Smit »
I zoomed in on the photos. Man! Does it ever look nice!
Keryn O'Shea
Re: J15 Build
#28 Post by Keryn O'Shea »
Clef's of Bass wrote: Fri Jul 05, 2024 6:20 pm Finally got some dye, poly, and Duratex on it...
That colour combo is excellent! Can you eleborate on the process you used for the Dye & poly please?
Your blue mug has the right attitude as well mate :D
Clef's of Bass
Re: J15 Build
#29 Post by Clef's of Bass »
Keryn O'Shea wrote: Sat Jul 06, 2024 5:15 pm That colour combo is excellent! Can you eleborate on the process you used for the Dye & poly please?
Thanks Keryn.
For the front of the cab, I started with ColorTone 'Vintage Amber' dye (undiluted) applied with an old cut-up T shirt. Let it dry overnight, lightly sanded back and dyed for a second time. Then, applied polyurethane (warm semi-gloss 2 coats).
For the sides and top, tapped off the front with blue painters tape and applied the Duratex with a foam textured roller.
Clef's of Bass
Re: J15 Build
#30 Post by Clef's of Bass »
The washer plate worked very well.
