Tinnitus Help, Maybe . . .
biodad
#1 Post by biodad »
Just came across this on YouTube. You can trust everything on the internet, right?
Does this work? I will try it .
Here is the heading to copy and paste in
MOST POWERFUL TINNITUS SOUND THERAPY 1 Hr|Tinnitus Treatment Ringing in Ears|Tinnitus Masking Sounds
Comments are always 100% honest, right? Read 'em, try it and see I guess. Good luck to all.
Re: Tinnitus Help, Maybe . . .
#2 Post by Bruce Weldy »
I've had tinnitus for over 30 years. I've seen a ton of claims that say they'll help. You can always try it. I've just learned to live with it. I go to sleep with the TV on a timer to mask it.
biodad
#3 Post by biodad »
Mine isn't bothersome except that the left ear is down a bunch from 5K on up. Lot of different opinions on
what works and usually it's nothing. Many truckers age 50 and older have a bad left ear from that window
being open many hours a day and that will kill the ear.
My local audiologist made me what he uses for hearring protection when he goes to concerts and I paid $150
for them. They allow 90% of the high end to come through so I hear most everything. All musicians need these.
When first putting them in, you will think you are missing things in the sound but you get use to them. If you take
them out half way through a performance, it is so bright and noisy you"ll understand why they are needed. Seriously,
dont F around with your hearring
#4 Post by Bruce Weldy »
biodad wrote: Wed Mar 06, 2024 11:22 am
You are absolutely correct. I have some earplugs that reduce the decibels but are pretty even across the spectrum. I really should use 'em more, but I'm not running loud rock shows like I used to. Still would be a good idea.
Stay away from the foam plugs.....they sound horrible, so nobody will use 'em. I got mine off the shelf at an audiologist's office. They were only about $15.
Keryn O'Shea
#5 Post by Keryn O'Shea »
This book has helped me greatly recently, having put up with tinnitus for 10 years, it ramped up in the last 6 months, I'll be fitted with hearing aids in two weeks for moderately severe hearing loss at 2k and 12k. Just using sound therapy, meditation and the information in this book has had quite a noticeable improvement, in two weeks!
Good news is that tinnitus is a side effect of increased gain in the auditory pathways, and in itself is harmless.. this alone helped me tremendously.
If tinnitus bothers you, get this book..
AT8 14", AT10 19", T30 28" LAB12, T48 36", THT 20", SLA 4x3"/4x4", CArray 6x4", TLAH, TLAP, J10 FA, J12 FA, OT8 CD, OT12 FA, OT15 CD, SLAP 2x6"/4x6", WH6 PA, WH8 MA, WH10 CD, DR280 MA, XF210.
shane2943
#6 Post by shane2943 »
This can help for temporary relief: https://mynoise.net/NoiseMachines/neuro ... erator.php
