Impressions of the THT.
Subsonicspectre
I finally got this bad boy rolling. I was having a giggle when the whole house started shaking @20hz although I will have to get a piece of carpet to put under it as the subwoofer started walking across the floor. Luckily where I wanted to put it is perfect with no nulls in my 2 listening positions.
I beyond impressed with how clean the bass is.
Keryn O'Shea
Re: Impressions of the THT.
The THT does it effortlessly..
Great job nailing a sweet spot first up
I have 6 of them in my living room...3K watts..nice movie bass..live Helicopters anybody
- marcoaandrade
Amazing! BTW, how wide is your Little Monster? Are you using 12 or 15in?Subsonicspectre wrote: ↑Mon Feb 19, 2024 6:13 pm I finally got this bad boy rolling. I was having a giggle when the whole house started shaking @20hz although I will have to get a piece of carpet to put under it as the subwoofer started walking across the floor. Luckily where I wanted to put it is perfect with no nulls in my 2 listening positions.
Cheers from Brazil
Subsonicspectre
I'm using the 15" so it's 36x36x24marcoaandrade wrote: ↑Thu Feb 22, 2024 5:01 pmAmazing! BTW, how wide is your Little Monster? Are you using 12 or 15in?Subsonicspectre wrote: ↑Mon Feb 19, 2024 6:13 pm I finally got this bad boy rolling. I was having a giggle when the whole house started shaking @20hz although I will have to get a piece of carpet to put under it as the subwoofer started walking across the floor. Luckily where I wanted to put it is perfect with no nulls in my 2 listening positions.
Cheers from Brazil
Subsonicspectre
- marcoaandrade
Ok...just to understand, since 15in THT panel vary from 17 to 35 in...Subsonicspectre wrote: ↑Sat Feb 24, 2024 11:54 pmI'm using the 15" so it's 36x36x24marcoaandrade wrote: ↑Thu Feb 22, 2024 5:01 pmAmazing! BTW, how wide is your Little Monster? Are you using 12 or 15in?Subsonicspectre wrote: ↑Mon Feb 19, 2024 6:13 pm I finally got this bad boy rolling. I was having a giggle when the whole house started shaking @20hz although I will have to get a piece of carpet to put under it as the subwoofer started walking across the floor. Luckily where I wanted to put it is perfect with no nulls in my 2 listening positions.
Cheers from Brazil
Subsonicspectre
If I remember correctly that is true. But getting it through a doorway might be difficult with a 35" width. Even at 24" wide it digs down to 22 hz nicely. Strong at 25hz, and up with smooth effortless detail.marcoaandrade wrote: ↑Tue Feb 27, 2024 11:49 amOk...just to understand, since 15in THT panel vary from 17 to 35 in...Subsonicspectre wrote: ↑Sat Feb 24, 2024 11:54 pmmarcoaandrade wrote: ↑Thu Feb 22, 2024 5:01 pm
Cheers from Brazil
The last 9 years have flown by for me, I built 4 THT's for my home theater in 2015, see https://billfitzmaurice.info/forum/view ... hp?t=23085
I never reported on their performance before, so belatedly here it is. One word "gobsmacking".
I ended up having an ischemic stroke in 2019 that slowed me down a bit, I made a full recovery with no permanent neurological damage and part of that recovery was hours spent listening to music in my home theater, the four corner placed THT's are just sublime, its not the tooth rattling volume capability that's impressive it's the whole room coverage with zero distortion of "realistic" clean bass reproduction that is unbeatable no matter how much you might spend on commercial subwoofers.
Thank you Bill.
Thank you Bill.
Matthewg007
Just finished my THT build standard 24.5” wide. I like the PL 8x for the stick on the vertical.
DRIVER:
Dayton Audio RSS390HO-4 15" Reference Series HO Subwoofer 4 Ohm
AMP:
Crown xls 1002. (Bridge mode, band pass 30hz / 100hz)
Receiver:
YAMAHA RX-A6A
FEET:
Silicone Speaker Isolation Feet (8-Pack, 1.25") – Non-Skid Adhesive Pads for Turntable, Subwoofer & Audio Equipment – Vibration Dampening, 20 Duro Rubber
Speaker output 1ft off the wall in front left corner.
I worked at BOSE for 21 years… and SWEET JESUS Bill!! Now, I need to go get some plaster to fix the cracks in the walls after watching the opening scene of Star Wars. Brought me back to 1978 in a flash.
I tip my hat good sir.
DRIVER:
AMP:
Receiver:
YAMAHA RX-A6A
FEET:
