How many braces? TubaHT LP, 36".
DriftlessIA
#1 Post by DriftlessIA »
I am building a TubaHT Low Profile in 36" width. In the build instructions, it says that you can use 3 sets of braces for enclosures that are wider than 25", but not to exceed 8" in between braces.
A 36" wide enclosure with three sets of braces would have them spaced apart 8.375" (more than 8").
A 36" wide enclosure with four sets of braces would have them spaced apart 6.6".
Which would you choose, three or four sets? I've seen both used in photos online.
'85 LaScalas
VTA ST-70 tube amp
Bluesound Node 2i
TubaHT LP, 36" width
18" Ultimax, sealed
Re: How many braces? TubaHT LP, 36".
#2 Post by Seth »
Welcome to the forum. I'm Seth.
I would personally choose four between panels 9 & 4, three between panels 4 & 7, four between panels 7 & 1, and flip a coin for mouth braces. Heads three, tails four.
By the looks of the photo, it's a little too late to ask, isn't it? Or, is that not yours? Looking pretty good either way :thumbsup:
DriftlessIA
#3 Post by DriftlessIA »
Thanks, Seth.
That is a photo that I found online. My panels are all cut, and I'm a couple of days away from starting assembly.
I had a similar thought as your suggestion. I appreciate your input.
'85 LaScalas
VTA ST-70 tube amp
Bluesound Node 2i
18" Ultimax, sealed
#4 Post by Bill Fitzmaurice »
You can't have too many braces. You can have too few.
#5 Post by Tom Smit »
@DriftlessIA Welcome to the forum!
DriftlessIA
#6 Post by DriftlessIA »
Thank you, Tom!
'85 LaScalas
VTA ST-70 tube amp
Bluesound Node 2i
18" Ultimax, sealed
