Ha, point taken!!Bill Fitzmaurice wrote: ↑Sat Nov 04, 2023 5:47 am If it ain't broken don't try to fix it. My TT and 75 watt plate amp are 20 years old, and they operate at least 8 hours a day.
I just wanted as more curious if over the years a better ( more capable ) driver / amp was available , just to get the most out of the actual enclosure
The amp I don't see being as drastic , other than maybe having a DSP as not much power is used
The driver on the other hand I guessed might have room for improvement?
Lavoce, eminence, or even the Dayton um15 all seem like more capable drivers, but I also realize there was a reason you recommended the driver I have, 12+ years ago when I built it..
