table tuba
mino00
table tuba
#1 Post by mino00 »
https://www.sweetwater.com/c1085--B_Amp ... lsrc=aw.ds
this speaker good for table tuba
thanks
mino00
Re: table tuba
#2 Post by mino00 »
https://www.parts-express.com/Dayton-Au ... H5EALw_wcB
how a bout this one compare to the above speaker.
thanks
Re: table tuba
#3 Post by Grant Bunter »
Both those drivers aren't in the plans as recommended.
Go to PE and search for Dayton Audio DCS205-4, which is a recommended 8" driver, and sells for $75.
If you want a 10" driver, the Dayton DCS255-4 is a recommended driver, at $99...
mino00
Re: table tuba
#4 Post by mino00 »
Thanks for quick response on the other thread Biil recomended Dayton Audio LS10-44 10" Low Profile Subwoofer Dual 4 Ohm , May be i m wrong
thanks
Re: table tuba
#5 Post by Grant Bunter »
mino00 wrote: Sun May 07, 2023 10:56 pm Thanks for quick response on the other thread Biil recomended Dayton Audio LS10-44 10" Low Profile Subwoofer Dual 4 Ohm , May be i m wrong
thanks
The two I put up are certainly in my (now very old) plans.
If Bill has said yes to something, it's good.
The LS10-44 is a dual voice coil variant though.
So it's going to be hard to make that 4 ohms if that's what you're aiming for.
