Bill Fitzmaurice wrote: ↑Fri Jan 06, 2023 9:34 am
He also rotated the piece in the wrong direction. You rotate the piece into the blade, with your hand on the piece on the side of it opposite the blade. He's lucky he didn't lose a finger or two.
Cutting circles on a table saw is an "iffy" operation at best. Looks really unsafe to me. Only way I consider it is if I moved the sled and workpiece to the cutline, stop, turn off the saw. Firmly attach the sled to the saw, the start up the saw and rotate the piece slowly.
But, I can think of a few better ways to make a circle.
It's not dangerous at all if you follow Rule #1, never have your hands near the blade, and Rule #2, always push the work into the blade. He broke both. I cut large circles on my router table, which is wood. After cutting the part to a square the diameter of the circle I put the center point of one edge to the router bit, drive a screw through the center of the square into the table, start the router and then turn the square, feeding the cut into the bit.
In the accompanying story, he explains that he was using that area to pull the sled back. If you watch it again, it's pretty obvious that's what he was doing when the circle caught the blade and spun unintentionally. If I pointed a finger at him, laughed at his lack of foresight, and claimed to never have learned something the hard way... I'd be a big fat liar. Somehow I've managed to keep all ten fingers and toes... just enough forethought I guess. So far, anyway.
My cousin... not-so-much (note that the table saw blade tooth "V" shape can be made out on the x-ray)
Bill Fitzmaurice wrote: ↑Fri Jan 06, 2023 11:09 am
Agreed. Also, rule #1 is imperative. If you can't follow it then you have no business operating any power tool with a rotating blade.
Bruce Weldy wrote: ↑Fri Jan 06, 2023 9:44 am
I respectfully completely disagree with you on this. This is the fastest and simplest way to cut circles with near perfect repeatability and minimal dust.
Besides, its not like the router method isn't without risk. Rotating a router around a fixed jig while avoiding power cables and clamps is also dangerous.
That's not how it works. If you zoom in on my picture you'll see very small triangular cuts. These are straight sled cuts. I'll try to explain.
1. Nail to sled. Pilot drill (slightly smaller diameter) for the center nail, then nail it to the sled.
2. Straight sled cuts! This step takes the longest. Put downward pressure on the cut piece (so it does not rotate on the blade) while pushing the sled through the cut. Pull the sled back and then slightly rotate and repeat until no material extends to the opposite side of the blade.
3. Rotate the cut piece on the blade. The final step. Once most of the material is gone from the straight cuts, you rotate the cut piece into the cutting direction on the blade. Done
I understand the process, but I'd use a router any day over that. I guess everyone has to choose their own risk/reward quotient. The older I get, the more careful I get in the shop.
Ok, back to the thread. Sorry for the long delay in posts. Got real busy with holiday travel, family and work. Now that we're past all that back to the fun hobbies.
Guess how much this thing weighs? Could be a little lighter but I added rubber feet to the rear panel for transit and another handle on the bottom opposite of the top so you can carry it horizontally.
Take a look at how well it travels in the truck!
I'll try to get better pictures and post some more later.
Tom Smit wrote: ↑Sat Jan 14, 2023 11:32 pm
Side note: I am curious... why you have a Matco toolbox in your garage? I only have a no-name brand one in my shed. LOL.
I bought it used from an old retired School Bus mechanic in Louisville. Kinda funny, he had it in his 10th floor apartment. I remember the weird looks the other apartment residents gave me while using the elevator to get it out. Luckily it fit in my subaru i had at the time.
