No, this isn't the actual dial of my unit. It is a unit with only a little depth, so a live picture of it would be difficult (cables in the way). It was a close-up from a stock photo to aid the conversation. My dial was set to about 125 Hz. I reduced it now to 80 Hz following the suggestions here.
Thanks for the PM. I do use WA, but also Signal, Threema and Telegram as I am trying not to give Facebook more information than absolutely neccessary. I don't have a profile there, but I know with me using WA, they still collect my data. I was about to sent out the first message, but reminded myself of the time difference and let you sleep through your night
@Grant: As for the signal flow: So if I EQ before cross-over, I cant distinguish between the low frequency range feed to the tops and the sub. All I can do is to balance the sound in general and use the dails of the cross-over to make the cut for the LF to optimize who gets what. That would be basically to decide what the Subs to recieve and what the mains still have to handle as the Low output of the cross-over would get fed into the amplifier for the subs. Is that correct?
And what am I to do with the High and the Mid out? I would need to combine those back together for amplification to go into the tops. Am I not adding distortions by cutting and recombining those signals?
Back to work:)
Thanks guys!
André
(I know, quite bold as I have gotten plenty of good tips already. Thanks guys!)
