Curvearray questions
Keryn O'Shea
Good evening all,
I'm looking for suggestions on a way to build something to drop tweeters on top of the pictured Curvearray. I built it way back when without tweeters.. not sure why. I had a single silk dome sitting at the front/centre, that was cute, but wasn't really cutting it. I'm also free to use more than 6 tweeters, would you go nine? And finally should I even bother as they'll be quite a distance from the mids?
Re: Curvearray questions
Welcome back Keryn, LTNS!
I had a thought, check out Wagner's website (or WES components if you are a registered user, same people) at their ribbons.
Ribbons have come way down in price, there might be something simple and cute to throw in a little box that does the trick???
Or, rebuild the box with the drivers you have, and add tweets...
I'd duplicate the existing box made just high enough for six tweeters. Either that or start over.
What's the measurement from the top of the woofer cut out to the top of the cab? Is there not enough room to drill and put surface mount tweeters there?
Keryn O'Shea
Thank you for your responses gentlemen,
Cheers Grant, yes it's been many moons! Ok I'll check out the ribbons man, I've not had any experience with them.
Yes Bill it's looking that way if I want to have the six tweeters in this cab to start over. We're still trying to have a shed built here at our new premises, so I've nowhere to make proper dust atm. A 9 driver/tweeter Curvearray is the first cab on my list to build though when that happens.
Seth, the driver cutouts are centred on the baffle so there's not enough room for a GT-302 above the mid, even shaving both component frames and the inner of the cab, I just sat over at the cab with a GT-302 to find that out, but... I noticed that there is enough room to fit 5 tweeters in between each mid on the join of each baffle. I can sort the gap at the tweeter frame with something.
So now my question is, would five tweeters work out with impedance/filters..
Actually there could be 2 tweeters on the centre baffle join, that makes 6. If I'm making a mess of this now, just tell me and I'll let myself out..
Keryn O'Shea
If the tweeters were to be built into a frame which sits on top of this cab, would they be too far away from the mids?
Less than ideal, but serviceable. You'd have to be within three feet or so to notice any problem.
A couple thoughts I had on possible solutions...
- Mount the tweeters in front of the woofer on two strips of wood that bridge the woofer cutout.
- Mount the tweeters behind a cloth grill that fits to the face of the array, hiding any unsightly overlap.
- Get tweeters with smaller frame dimensions that would fit your existing available space.
- Router filler discs, glue them in the existing driver cutouts, fill any voids with Bondo, sand flush, relocate the cutouts lower, allowing the tweeters to be mounted above. Still way less work than building one from scratch.
Keryn O'Shea
Excellent, thank you all very much for your input and help with this minor and possibly annoying venture, there's some interesting fabrication ideas there Seth!
Heck, if you were to go to all that trouble, why not just redo the baffle from scratch.
Cut out the existing baffle with a multitool, pop a new one in that has everything in the right place.
Way faster, easier to work, sand etc.
Provided there's enough room to add tweets or lower the drivers...
I did a TruckTuba that I started out per the plans. Then, I switched gears and put the drivers on a completely different pannel after I'd already cut the hole in the original designated spot. It was way easier to fill the already cut 8" hole than I thought it woud be. After filling, sanding, and paint (duratex) the original hole is completely indistinguishable from the rest of the original panel. Looks completely normal, as if there wasn't ever a hole there.
Doing the same may work out well for you, but you may need to create a circle template and use a pattern following bit to be able to get your router into each angled piece/baffle.
Whether you take that and run with it, or go another direction, I look forward to seeing your results! Please keep us posted (with pics!).
You could also "raise the roof" of the cabinet.
Mark off the inner sides sides of the side pieces onto the top (as if you had x-ray vision and were looking down and through the top, seeing the side boards.)
Drill four corner holes inboard of the sides, so that you don't damage them.
Connect the holes with a jigsaw, avoiding the baffle until you can see what you're doing.
Then glue another, new top piece on top, extending the height of the cabinet by the thickness of the original top (that you just cut most of off.)
You should pick up about 12.5 mm of real estate to work with. If 12mm isn't enough to do the job add furring strips of adequate thickness.
Keryn O'Shea
They'd be an easy shape to work with Grant, I'm sure they would sound amazing, but they would blow the budget unfortunately!
Great site though, cheers for that.
That would almost get them in Rich, however...
Yes, with a 9 driver cab! The more I look at it, cutting into a finished cab unless there was something quite wrong with it (like not enough braces in a T30Grant Bunter wrote: ↑Sat Sep 03, 2022 4:29 pm Heck, if you were to go to all that trouble, why not just redo the baffle from scratch.
Would I be losing anything from the woofers if they were mounted in front? And if they were mounted any further forward of the woofer, would that cause a problem with sound?
Putting them in front will cause some loss of upper midrange. Frequencies with a wavelength significantly greater than the diameter of the tweeters will go around them, but frequencies with a wavelength shorter than that won't.
Keryn O'Shea
Ok thank you Bill, I'll clear a spot somewhere and get to mocking something up..
