Simplex 2x12 Sealed - eliminate handle - Impact on internal volume
Our easiest to build speaker lineup.
Jakevw
#1 Post by Jakevw »
If I omit the 4x flush-mounted handles in the design, to go with surface-mounted handles (aka old-school Fender), will there be negative impact on the internal volume and/or performance? Any concerns?
Re: Simplex - eliminate handle - Impact on internal volume
#2 Post by Bruce Weldy »
which Simplexx design are you talking about .... there are several.
Jakevw
#3 Post by Jakevw »
Simplex 2x12 sealed cabinet. This design has 4x flush-mounted handles, which may add up to some internal volume.
Re: Simplex 2x12 Sealed - eliminate handle - Impact on internal volume
#4 Post by Bill Fitzmaurice »
The effect will be negligible.
