Simplex 2x12 Sealed - eliminate handle - Impact on internal volume
If I omit the 4x flush-mounted handles in the design, to go with surface-mounted handles (aka old-school Fender), will there be negative impact on the internal volume and/or performance? Any concerns?
Re: Simplex - eliminate handle - Impact on internal volume
which Simplexx design are you talking about .... there are several.
Simplex 2x12 sealed cabinet. This design has 4x flush-mounted handles, which may add up to some internal volume.
Re: Simplex 2x12 Sealed - eliminate handle - Impact on internal volume
The effect will be negligible.
