Rounded Edges
Guitar cabs both you and your audience can hear better.
sloaneamps
Rounded Edges
#1 Post by sloaneamps »
Hi,
I’m wondering if any who have built the XF cabs have used a 1/2” round over router bit for the edges. I build guitar heads and use 3/4” wood with a 1/2” round over on my cabs. This way I can use the 1/2” metal corners. I’m looking to do the same on the XF cabs but using 1/2” wood with brad nails or screws looks like I’ll probably end up having the router bit hit the nails or screws. I was thinking of using 3/4” braces on the inside corners along with the PL glue so the nails or screws can fasten to the braces which would give enough clearance for the 1/2” round over bit. Would the braces be ok and not effect the sound?
Re: Rounded Edges
#2 Post by Bill Fitzmaurice »
The standard round over is 3/8". Using soft steel brads you can route right through them, and if you set the gun for a deep drive you may not hit them at all. Battens on the corners are old school. They don't make the joint any stronger, they just add unnecessary weight and complexity to the build.
sloaneamps
Re: Rounded Edges
#3 Post by sloaneamps »
Thanks. I was also thinking i would be able to route through them since I have decent carbide tip bits. If I do that then it probably wouldn’t matter if I used 3/8 or 1/2 inch. So no need for the battens. But I’m pretty sure my metal amp corners are made for 1/2 round over but it’s possible the the corners I have will work with 3/8 too
Re: Rounded Edges
#4 Post by Bill Fitzmaurice »
1/2" may be used with metal corners. I only use plastic, for their interlocking ability, and those I've used are 3/8".
Re: Rounded Edges
#5 Post by Bruce Weldy »
For what it's worth, I used the 3/8 roundover on my XF210 with no corners at all. Corners are a little tough to get looking right with the angled front.
Re: Rounded Edges
#6 Post by Bruce Weldy »
Oh, I did use corners on the bottom, just not on the top.
sloaneamps
Re: Rounded Edges
#7 Post by sloaneamps »
Thanks for reminding me that I will have to take the slant into consideration. I think 3/8 and 1/2 both look good but the metal corners that I use on my amp heads probably fit nicer on 1/2 round over. I also tolex the cabs so those corners hide the potential faults in my tolexing :D I think I need to do some experimenting with scrap wood
himhimself
Re: Rounded Edges
#8 Post by himhimself »
I used 3/8" roundover on both my T30s (1/2" BB, plastic stacking corners), as well as my Otop jarrays (1/4"BB, no corners due to the angles). I did use battens on the inside of the otops, just to give some bonus meat to the thin 1/4" sides when rounding over. Super strong, no issues.
2xT30 (20", 3012LF)
2xT30 (21", 3012LF)
Truck Tuba (MCM)
sloaneamps
Re: Rounded Edges
#9 Post by sloaneamps »
It turns out the metal corners I have fit better with 3/8" round over than the 1/2". Next question If I need to start a new thread I apologize and will move it. Can I make the box rectangular instead of slanted like the rectangular XF412?
Re: Rounded Edges
You can make the exterior rectangular, but the baffle back tilt angle must be maintained, just as it is in the 412. I advise against it, unless it's for the bottom cab in a stack.
sloaneamps
Re: Rounded Edges
#11 Post by sloaneamps »
Just curious as to why you advised against it is it due to the extra weight?
Re: Rounded Edges
#12 Post by Grant Bunter »
sloaneamps wrote: Tue Aug 03, 2021 3:32 pm Just curious as to why you advised against it is it due to the extra weight?
I'll take a punt.
The XF design is about not aiming the cab output at the guitarists knees.
That is the traditional approach, to aim at the knees. But the guitarist can rarely hear the cab that way.
The solution then becomes to turn up.
Then the rest of the band do the same.
All of a sudden, stage volume is painful.
Using the angled baffle makes it easier for the guitarists to hear the cab.
It wouldn't surprise me, with a cab like this, to do exactly the opposite of what they used to do.
And turn down, because "fark that's loud".
The tendency, in a rectangular style cab, will be to build it "traditionally" with a flat baffle, and that's not the design...
sloaneamps
Re: Rounded Edges
#13 Post by sloaneamps »
Yes I understand that purpose of the angled baffle and that should not be changed as Bill said. The question was if the cab cab can be rectangular, but still keep the correct angle on thr baffle.
Re: Rounded Edges
#14 Post by Grant Bunter »
sloaneamps wrote: Tue Aug 03, 2021 4:16 pm Yes I understand that purpose of the angled baffle and that should not be changed as Bill said. The question was if the cab cab can be rectangular, but still keep the correct angle on thr baffle.
All good.
An angled baffle in a rectangular cab will alter horizontal and vertical dispersion as well...
Re: Rounded Edges
Making the cab exterior rectangular will shade the highs a bit if you're standing close to it, especially with a 210 or 212.
