impeadence curves/ excursion
nick mineau
#1 Post by nick mineau »
hi,
I when you have a bass reflex speaker, the lowest point between the 2 impendence peaks, is the tuning frequency of the cabinet, and also the point of minimum excursion.
On a bass horn, how would we determine the points of minimum / maximum excursion, or tuning ?
I attached a random impendence curve from a bass horn, maybe we could use this as a example to teach me? is the low peak, the low limit? and then there are 2 sort of resonance peaks above that ?
Re: impeadence curves/ excursion
#2 Post by Bruce Weldy »
Not an expert (but I did stay in a Holiday Inn Express once... a long time ago) - Excursion is directly affected by power and frequency. The lower the impedance, the more power will be delivered. The lower the frequency, the more the cone will travel.....so, I'd say the point of the most excursion is going to be the lowest impedance near the lowest frequency.
In that graph, I'd say that the most excursion is going to occur at 50hz and from 30 down.... That's the layman's explanation. I'm sure those more knowledgeable will tell me the capacitor is on the wrong side of the inductor.
#3 Post by Bill Fitzmaurice »
You use a horn modeling software like HornResp to see excursion. The impedance peaks correspond with excursion peaks, but unlike a direct radiator there are many more of them.
#4 Post by Seth »
nick mineau wrote: Fri May 07, 2021 2:13 pm On a bass horn, how would we determine the points of minimum / maximum excursion, or tuning ?
Modeling software will give a calculated value of those performance results/parameters. However, it's a little time consuming learning to use the software and also unraveling the dimensions of the horn path for a given existing design.
http://www.hornresp.net/
nick mineau
#5 Post by nick mineau »
So, ill have to learn to play with that molder, but for sake of argument, would this horn have more excursion at 42hz, then it does at 80ish hz?
and what about comparing 35hz to 42hz? 35hz is a impendence low point sort of, so would it have less excursion then the peak at 42?
I'm guessing the answer is to model it lol
nick mineau
#6 Post by nick mineau »
sorry for the spelling errors
#7 Post by Bill Fitzmaurice »
I can't say, that impedance curve is out of the ordinary and suggests that it's not a pure horn. This is a T60 impedance chart:
#8 Post by Seth »
Bill Fitzmaurice wrote: Wed May 12, 2021 9:42 am I can't say, that impedance curve is out of the ordinary and suggests that it's not a pure horn. This is a T60 impedance chart:
Would you mind also posting the displacement plot? I think the two together may help in his curiosity of the relationship (if there is any) between impedance and excursion.
#9 Post by Bill Fitzmaurice »
nick mineau
#10 Post by nick mineau »
wow, these 2 charts used with each other is very informative. Thank you all very much for the intel.
