Tuba 45 Build
Re: Tuba 45 Build
Search: 'Murphy's Law'.
Re: Tuba 45 Build
Actually, in the interest of time management, it makes sense. Not sure that option would have occurred to me. Clever. You can always drill/plunge through, route out the access hole with a flush cut bit, and make a flange/hatch cover later.Rob Shasta Guitjr wrote:Wed Feb 03, 2021 10:19 am Hello Seth, this is Rob. There is a little over an hour and a mountain pass between Ashland and Mount Shasta. Between foul-weather and the shop production schedule, we will be closing these up this weekend. Bold move, but there will be no access port.
As a note: it has been a topic of discussion that an annual snugging of fasteners has commonly proven that it was actually needed. Just keep it in mind.
Re: Tuba 45 Build
That is absolutely true. I went through all my subs a couple of years ago - every one of 'em needed tightening......leaving off the access cover is not a good idea.
Pabloaguas
Re: Tuba 45 Build
Question- will I ever want to place these on their sides? We will probably button them up tomorrow and i'm wondering if I should install feet on one of the sides just in case. Would be much easier to do before closing them... and if i have them on the sides, would I want to mirror them? That is, have the bottoms facing each other?
Re: Tuba 45 Build
If you put on plastic cab corners, you will be covered. https://www.speakerhardware.com/hardwar ... t-corners/Pabloaguas wrote: ↑Wed Feb 03, 2021 10:33 pm Question- will I ever want to place these on their sides? We will probably button them up tomorrow and i'm wondering if I should install feet on one of the sides just in case. Would be much easier to do before closing them... and if i have them on the sides, would I want to mirror them? That is, have the bottoms facing each other?
Re: Tuba 45 Build
If your width dimension is less than your cab height, I could see putting them on their side to fit under something. Otherwise, as far as I know, it doesn't matter which side is up.
Pabloaguas
Re: Tuba 45 Build
Seth wrote: ↑Wed Feb 03, 2021 5:20 pmActually, in the interest of time management, it makes sense. Not sure that option would have occurred to me. Clever. You can always drill/plunge through, route out the access hole with a flush cut bit, and make a flange/hatch cover later.Rob Shasta Guitjr wrote:Wed Feb 03, 2021 10:19 am Hello Seth, this is Rob. There is a little over an hour and a mountain pass between Ashland and Mount Shasta. Between foul-weather and the shop production schedule, we will be closing these up this weekend. Bold move, but there will be no access port.
Yes, it seems to be easy enough to add the access door later if needed. Seems it might be hard to get a both good seal and tight fit.
Just got the 1/4” lag bolts in. Torqued to 5.5 nvm seems good will torque again before gluing side on
Pabloaguas
Re: Tuba 45 Build
Was planning to use these big-ol penn elcom metal corners and rubber feetTom Smit wrote: ↑Wed Feb 03, 2021 10:35 pmIf you put on plastic cab corners, you will be covered. https://www.speakerhardware.com/hardwar ... t-corners/Pabloaguas wrote: ↑Wed Feb 03, 2021 10:33 pm Question- will I ever want to place these on their sides? We will probably button them up tomorrow and i'm wondering if I should install feet on one of the sides just in case. Would be much easier to do before closing them... and if i have them on the sides, would I want to mirror them? That is, have the bottoms facing each other?
Pabloaguas
Re: Tuba 45 Build
Tom's right.....specifically, these corners... https://www.speakerhardware.com/penn-el ... corner.phpTom Smit wrote: ↑Wed Feb 03, 2021 10:35 pm
The great thing about these is that they not only serve to protect the cab on it's side, but you can stack the cabs on there side and they lock in. I've been doing that for years when I take out the full rig of T39s.
himhimself
Re: Tuba 45 Build
I have rubber feet on the bottom of my T30s that match the height of the casters on the back corners. I also have the plastic corners for when laying them on their side. You could always throw a cheap yoga mat underneath to protect a floor, and it will also help prevent them from walking around when they're pounding away. As for rubber feet, I have bought the 1.5 inch ones from Reliable Hardware off Amazon. Great solid, chunky feet, and cheap - usually about $5 for 8.
2xT30 (20", 3012LF)
2xT30 (21", 3012LF)
Truck Tuba (MCM)
2xT30 (21", 3012LF)
Truck Tuba (MCM)
Pabloaguas
Re: Tuba 45 Build
I had originally bought those corners but it seemed like the roundover on them was huge- like maybe a 5/8 inch radius... seems like we would be compromising the strength of the box to put such a huge roundover on the edges... that's why I decided to go with the flat corners...Bruce Weldy wrote: ↑Thu Feb 04, 2021 9:51 amTom's right.....specifically, these corners... https://www.speakerhardware.com/penn-el ... corner.phpTom Smit wrote: ↑Wed Feb 03, 2021 10:35 pm
Re: Tuba 45 Build
I changed all my corner to what Bruce posted and haven't looked back. Metal ones are for guitar or bass cabs
Re: Tuba 45 Build
3/8" roundover is plenty for those big corners. I've got 48 of 'em attached to my 6 T39s.Pabloaguas wrote: ↑Thu Feb 04, 2021 4:17 pm
Pabloaguas
