Before I soldered my DIY Cover for my Omni 12TB
Re: Before I soldered my DIY Cover for my Omni 12TB
In the bottom pic (for APT80), I recommend undoing one of the inductors (pick one, do the same on both boards) off the board, and standing it upright, as well as rotating it 90 degrees.
You had it that way in your first pic, so use that as a reference.
The other 2 are fine, solder away...
Ok Grant will do thanks for looking, I will solder away and use the first pic for the Apt 80 as reference standing the inductors up 90 degrees. I just want to let you know if the direction is right, the bottom Red/Blue lugs are from amp up arrow to drivers, correct?
BaasssS, . . how low can you GO!
Only one inductor on each board.
Otherwise ,direction, arrows ,all good...
Ok great I just redid it this morning hopefully I can solder now, thanks. Took me 20 hours but enjoyed for a first time doing crossovers.
Also Grant is it possible to do this cheap terminal 3 way lugs for the +1/-1 for NL 4 NL2 connector. All 3 positive attached in +1 and all 3 negative attached in -1.
Thank you for the help.
Go with that
Can you turn one of those over and take a pic for me please?
Its not connected if that is what you would like to know, I would have to solder a 16 awg wire across all three holes. If you can see what I am trying to get at? Thank you
Yep, do that then!
Use NL4, +1 to the red connectors, -1 to the blue...
Thank you Grant, I will do that definitely. Now looking forward how do I post a video of these Full Range Omni12TB
I guess, you would load it to youtube and post the link...
Ok I will sign into youtube, thanks!
Don't play the cab too loudly lest you distort the recording mic.
But do turn it right up just before you finish recording and take a selfie
Ok Tom and Grant will do. Also if I don't like the sound of the tweeters can I put an L-Pad after the cab is finished with paint? I can manage to put a hole on the side of the cab for the mounting of the L-Pad. Also can I get away with just turning down some of the high frequency on the EQ. Thanks guys
