Djay from France ;)
djay_72
Djay from France ;)
#1 Post by djay_72 »
Hi,
I’m 36, from Le Mans, and would like to build my own sub for my KEF Home Theater...
I would like to order plans, could you give the vector files ?
I’m serching for the best Home Theater Sub, with this dimensions :
High : 55cm Max
Width : 60cm Max
Depth : 60cm Max
What could you recommend ?
I’ve a CNC and teck wood furniture in the living room, what do you think about building on this wood ? And wich thickness ?
Thank you
Regards
Jérôme
Re: Djay from France ;)
#2 Post by Grant Bunter »
Hi, and welcome to the forum :)
You would have to create your own vector files from the plans.
Are your required dimensions a deal breaker? The nearest HT design from Bill would be the Table Tuba:
https://billfitzmaurice.info/TT.html
The material used to build all these cabs is 1/2" or 12mm plywood.
I guess you could dress anything you build if tech wood comes as a veneer...
djay_72
#3 Post by djay_72 »
Thank you Grant !
Yes size are really a deal breaker ! Table Tuba is what you would recommend for HT with my dimensions ?
djay_72
#4 Post by djay_72 »
30x30x16 I can’t... Max 20x20x20
#5 Post by Grant Bunter »
errr you said 60cm in your first post, and that's pretty much 24" inches.
Is 60cm you max or no?
I would recommend a HT design, but none of those are in the dimensions you require.
If it must be those dimensions, look at a Tuba 24...
#6 Post by Bill Fitzmaurice »
Tuba 24 isn't an HT sub. It's made to go loud, but not home theater low. Simplexx 15 Sub is 51cm wide, 51cm deep, 60cm high.
djay_72
#7 Post by djay_72 »
Simplexx would be good in HT ? And good with Hifi too ?
djay_72
#8 Post by djay_72 »
Yes Max about 23x23x20 Grant sorry
jimbo7
#9 Post by jimbo7 »
Can the sub be disguised as an end-table or other piece of furniture? A Truck Tuba might fit under a couch (but I already know what others are gonna say...)
Strange Kevin
#10 Post by Strange Kevin »
The only horn loaded subs that would fit in that space would be the Tuba 18 or Tall Autotuba, but with a short horn length they may not go as low as you may want a Home theater sub to go.
The Simplex 15 looks to be a good fit. And may easiest solution.
As to making it look pretty,
Here is a link to a T18 build for some inspiration.
viewtopic.php?f=30&t=24541
djay_72
#11 Post by djay_72 »
Yes, think about the Simplex 15 too, and no, table is already on place...
What do you think for the best speaker for it ? What about an Earthquake dbxi15d ?
rfauske
#12 Post by rfauske »
Just use the ones that is recomended in the plans.
