Djay from France ;)
Djay from France ;)
Hi,
I’m 36, from Le Mans, and would like to build my own sub for my KEF Home Theater...
I would like to order plans, could you give the vector files ?
I’m serching for the best Home Theater Sub, with this dimensions :
High : 55cm Max
Width : 60cm Max
Depth : 60cm Max
What could you recommend ?
I’ve a CNC and teck wood furniture in the living room, what do you think about building on this wood ? And wich thickness ?
Thank you
Regards
Jérôme
High : 55cm Max
Width : 60cm Max
Depth : 60cm Max
Thank you
Regards
Jérôme
Re: Djay from France ;)
Hi, and welcome to the forum
You would have to create your own vector files from the plans.
Are your required dimensions a deal breaker? The nearest HT design from Bill would be the Table Tuba:
https://billfitzmaurice.info/TT.html
The material used to build all these cabs is 1/2" or 12mm plywood.
I guess you could dress anything you build if tech wood comes as a veneer...
Thank you Grant !
Yes size are really a deal breaker ! Table Tuba is what you would recommend for HT with my dimensions ?
30x30x16 I can’t... Max 20x20x20
errr you said 60cm in your first post, and that's pretty much 24" inches.
Is 60cm you max or no?
I would recommend a HT design, but none of those are in the dimensions you require.
If it must be those dimensions, look at a Tuba 24...
Tuba 24 isn't an HT sub. It's made to go loud, but not home theater low. Simplexx 15 Sub is 51cm wide, 51cm deep, 60cm high.
Simplexx would be good in HT ? And good with Hifi too ?
Yes Max about 23x23x20 Grant sorry
Can the sub be disguised as an end-table or other piece of furniture? A Truck Tuba might fit under a couch (but I already know what others are gonna say...)
- Strange Kevin
The only horn loaded subs that would fit in that space would be the Tuba 18 or Tall Autotuba, but with a short horn length they may not go as low as you may want a Home theater sub to go.
The Simplex 15 looks to be a good fit. And may easiest solution.
As to making it look pretty,
Here is a link to a T18 build for some inspiration.
viewtopic.php?f=30&t=24541
Yes, think about the Simplex 15 too, and no, table is already on place...
What do you think for the best speaker for it ? What about an Earthquake dbxi15d ?
Just use the ones that is recomended in the plans.
