Tuba 30 bass sick Dual kappalite 3012LF
Rickwired
#1 Post by Rickwired »
:hyper:
This thing bumps! Man I am overly impressed and about to start the next one tomorrow. Should go quicker now that I’m familiar with how to make them.
Its
4- 29” tuba 30 w/ dual kappalite 3012lf
2 - 18” tuba 30 w/ 3012lf
4 - OT12 w/ 3012HO and crossfiring tweeter array
2 more OT12 w/ 3012HO and tweeter arrays in progress
commander_dan
Re: Tuba 30 bass sick Dual kappalite 3012LF
#2 Post by commander_dan »
Nice huh! What did that beast weigh in at? Moar pics also.
6 T30 (24", 3012LF)
2 OT12 (MA, 3012HO)
2 T24 (18", 3010LF)
Running:
DCX2496
XTi 2002
XTi 4002
TRAKTOR Z2
TECHNICS 1210 Mk5's
Rickwired
#3 Post by Rickwired »
Haven’t put it on a scale but it’s 30x30x29 and has the 2 kappalites which are about 7lbs each
#4 Post by Tom Smit »
Nice!
Welcome to the forum!
J_Dunavin
#5 Post by J_Dunavin »
Looks good man!
What are you going to use em for? DJ use?
Rickwired
#6 Post by Rickwired »
For DJ use. House and Techno mainly.. it came in at 115lbs. Heavy but man does this thing hummmm. Just started the next one and should have a majority done by this weekend.
I’m hoping to have it done for next week. We have an outdoor gig and want to run 2 of these bad boys. All of my buddies can’t believe the bass these things put out. After showing them they’re all believers now. Next on the agenda is some OT12’s only cause I don’t know if I could make the DRs.
commander_dan
#7 Post by commander_dan »
You'll be happy with the OT12s, they are amazing. My pair keeps up with my 6 T30s outdoors if that gives you any idea..
6 T30 (24", 3012LF)
2 OT12 (MA, 3012HO)
2 T24 (18", 3010LF)
Running:
DCX2496
XTi 2002
XTi 4002
TRAKTOR Z2
TECHNICS 1210 Mk5's
CoronaOperator
#8 Post by CoronaOperator »
Rickwired wrote: Tue Jan 08, 2019 6:05 pm Heavy but man does this thing hummmm.
Nice build! Hope you have a high pass and limiter set as per the plans. These things stop humming if overdriven without warning. Plenty of folks here to help you set that up if need be.
Rickwired
#9 Post by Rickwired »
CoronaOperator wrote: Wed Jan 09, 2019 2:53 am
Would a DBX driverack do everything I need?
#10 Post by Bruce Weldy »
Rickwired wrote: Fri Jan 11, 2019 12:29 am
Yes
J_Dunavin
#11 Post by J_Dunavin »
+1 on the Driverack
I have an older PA+ and tri amp my whole setup.
It’s fantastic
ACUA
#12 Post by ACUA »
Plus 2 for the DBX driverack it is vital my opinion!!! Filters, eq, delay, auto eq, easy enough interface with iPad or tablet!!!
#13 Post by Bruce Weldy »
ACUA wrote: Fri Jan 11, 2019 5:21 pm easy enough interface with iPad or tablet!!!
That's only with the PA2. No interface with the PA, PA+, or PX. But they all get the job done equally well for the needs here.
Rickwired
#14 Post by Rickwired »
Ordered the PA2 should be here in time for this weekend. Any suggestions on high and low pass freqs for these? 2 - dual loaded 3012LF gonna be using them with a pair of mackie srm450. I’m new to this type of sub... I usually just have a powered qsc kw181.
commander_dan
#15 Post by commander_dan »
Single dual loaded T30: HP 35hz, LP 100hz
Pair dual loaded T30: HP 30hz, LP 100hz
I never bother bringing any mains lower than 100hz with these subs even if they have the ability to.
6 T30 (24", 3012LF)
2 OT12 (MA, 3012HO)
2 T24 (18", 3010LF)
Running:
DCX2496
XTi 2002
XTi 4002
TRAKTOR Z2
TECHNICS 1210 Mk5's
