WH10 build started
Preston
Re: WH10 build started
#31 Post by Preston »
Rolling on black Duratex
Finish in progress.jpg (16.6 KiB) Viewed 1628 times
Preston
#32 Post by Preston »
Got the drivers installed
Mounted Drivers.jpg (16.6 KiB) Viewed 1628 times
Preston
#33 Post by Preston »
Covers fit nicely. Got two of them buttoned up.
Duratex Covers.jpg (14.85 KiB) Viewed 1628 times
Preston
#34 Post by Preston »
Mounting the drivers was an exercise in patience. Recex screws and a small ratchet made it not too horrible. Lost track of how many times I dropped the bit before I figured out that a little piece of tape on the tool would fix that.
#35 Post by Tom Smit »
If you place a piece of paper over the holder, and then push the bit into the holder, the paper will keep it tight.
Preston
#36 Post by Preston »
I need a little help. I'm having trouble with the frames to make a pet screen grill. I first tried making the angled cuts on all sides before assembly, but the frames fell apart almost right away. I then tried building the frames with flat stock first and then cutting the angles, also a disaster. Any tips?
#37 Post by Bruce Weldy »
Preston wrote:I need a little help. I'm having trouble with the frames to make a pet screen grill. I first tried making the angled cuts on all sides before assembly, but the frames fell apart almost right away. I then tried building the frames with flat stock first and then cutting the angles, also a disaster. Any tips?
Don't mean to sound harsh, but you should abandon this whole idea. These are not cabs that sit in your living room. They need to be able to stand life on the road....even if it's just a few nights a month.
Put grills on them and back 'em with some foam. They will look professional and the be much more rugged.
Here's what that looks like on the WH10s I built a few years ago.
Preston
#38 Post by Preston »
Thank you Bruce. I'll see if I can source some metal grills for them. I was going to use pet screen because that's what I have on my OT12's and it's held up wonderfully with many years of regular gigging.
#39 Post by Bruce Weldy »
This is the place that I ordered mine for the WH10s and my OT12s.
This one has over 60% open area.
http://www.reliablehardware.com/customs ... gered.aspx
Preston
#40 Post by Preston »
Just a shot of some corners and input jack installed.
Preston
#41 Post by Preston »
I did order some metal grills yesterday and will back them with foam.
#42 Post by Bruce Weldy »
Preston wrote:I did order some metal grills yesterday and will back them with foam.
You'll like it.
The foam is available from Wal-Mart. Go to the Air-conditioning section. It's the foam that is used for window units. You'll have to do a splice on it, since it's not wide enough.
#43 Post by Bruce Weldy »
Here's a link to my WH10 Build a few years back.....there's a little part on the foam and how I attached it to the grills. I think it's on the second page. It's based on the old plans, but that doesn't affect the grills.
http://billfitzmaurice.info/forum/viewt ... 30&t=15107
Preston
#44 Post by Preston »
I built and installed the frames for the metal grills
grill frames.jpg (17.75 KiB) Viewed 1493 times
Preston
#45 Post by Preston »
Did a little work on the melded arrays: added the diffuser.
Taped Up.jpg (14.48 KiB) Viewed 1493 times
Glued Up.jpg (16.7 KiB) Viewed 1493 times
Painted UP.jpg (16.64 KiB) Viewed 1493 times
