T60 x2 build
samaharris
T60 x2 build
#1 Post by samaharris »
I started building my T60's the other day and thought I'd share a couple of photos.
Both T60's are being constructed at the same time so I can make sure they are identical.
Panels are 450mm wide (just under 18") so overall width is 474mm (just under 19") and therefore obviously single Lab 12 loaded
Marking out all the panels joins on one side
Cutting out the access cover
I'm waiting for the PL Premium adhesive from the Budget group to arrive before I can progress :wall: . Should be arriving soon since I ordered last week.
Panels 1 and 2 cut and ready to be glued
My work space isn't huge but I'll make do with what I've got.
Many more photos to come
4 x single loaded Tuba 60 19" LAB12
4 x WH8 Delta, melded 8 tweeter
4 x SLA PRO 4 x 6"
SimonD
Re: T60 x2 build
#2 Post by SimonD »
Hi Sam
How much PL did you have to order? I might take some off your hands if you had to get a whole carton.
2 x DR250 (Kappalite 3010MB, ASD1001S)
2 X T39 24" (Kappalite 3012LF)
samaharris
Re: T60 x2 build
#3 Post by samaharris »
Yeah, I ordered a whole carton.
Not sure how much of it I'll use but I'll hang on to half of them for future builds.
I'd be happy to get rid of a couple. How many are you after?
4 x SLA PRO 4 x 6"
SimonD
Re: T60 x2 build
#4 Post by SimonD »
I'll take 4 please Sam. I sent you my number on a PM a few days ago.
Cheers S
bitSmasher
Re: T60 x2 build
#5 Post by bitSmasher »
Quick progress after making an introduction!
You mentioned outdoor parties, what music? There were some T60s doing doofs somewhere around W.A, are they still in use?
Also, where'd you source the plywood?
Rich4349
Pressure plate
#6 Post by Rich4349 »
Hey Bill- why is it that the T-60s seem to be the only tuba that uses the "pressure plate" aperture panel that the titans, DRs, etc use?
samaharris
Re: T60 x2 build
#7 Post by samaharris »
bitSmasher wrote:You mentioned outdoor parties, what music?
Other people provide the music, I just provide the gear.
It ranges quite a bit, but there's usually a lot of bass heavy music. I wouldn't be able to say exactly what though.
bitSmasher wrote:where'd you source the plywood?
I got it from a place called Colli. They are a local lumber yard and the wood seemed to be fairly good quality.
Also, my glue arrived and I've started joining the first couple of panels. Pics to come soon.
4 x SLA PRO 4 x 6"
samaharris
Re: T60 x2 build
#8 Post by samaharris »
After a bit of a break from work and 'all night' parties for Australia Day, I'm back to work on the T60
4 x SLA PRO 4 x 6"
escapemcp
Re: T60 x2 build
#9 Post by escapemcp »
Yay! :hyper:
samaharris
Re: T60 x2 build
#10 Post by samaharris »
More progress being made
Top panel and brace installed
Handholds cut
Handholds cut
Back panel and brace installed
ordering the Duratex tomorrow
Should be finishing the first T60 soon :hyper:
4 x SLA PRO 4 x 6"
samaharris
Re: T60 x2 build
#11 Post by samaharris »
More progress. Power outage forced me to stop work for a day :cussing:
getting really excited to have the first one working :hyper:
4 x SLA PRO 4 x 6"
escapemcp
Re: T60 x2 build
#12 Post by escapemcp »
samaharris wrote:More progress. Power outage forced me to stop work for a day :cussing:
If you do outdoor parties, don't you have a generator :confused:
Nice work on the sub btw :)
samaharris
Re: T60 x2 build
#13 Post by samaharris »
So close to finishing
All braces installed and insides painted
Second side glued and screwed
Driver installed and wired
PL squeeze out on all joins
Just have to do the air leak test, paint the outside in Duratex, install the cabinet hardware and seal the access cover.
Will be doing that plus a good testing tomorrow
4 x SLA PRO 4 x 6"
SimonD
Re: T60 x2 build
#14 Post by SimonD »
Hi Sam, Looking great, did you manage to source any speaker sealing tape?
Re: T60 x2 build
#15 Post by Grant Bunter »
Very nice Sam.
Looking forward to the end result...
