RTA'd my speakers, here's what I got. What does it mean?
Dan56
#1 Post by Dan56 »
I set up the OT12, melded array on top of the T39 (28" wide) with the Driverack PA+. The mic was set about 18' in front about 4' off the ground. After sitting there having turned up the noise waiting for it to do it's thing and getting messages to turn up, turn down I decided to hit "next page" and bingo! It finally ran the test. Ok, got it now.
The first pass, the xover at 100/112 and zero gain, the larger variances were:
630k and 800k -6.0 db (this is consistent through out all the tests)
3.5K -3db
4.0K -5.5db (this was consistent -5.5 to -6 through out the tests)
8.0K -3.5 db
10K -3.5 dgb
Anything that was above zero was not over +3 db
So, I ended up on the final test boosting the sub+3 db and cutting the OT12 -3db and the final results that were not 2db +/- were:
50K +3 db
125 +3db
160 +3 db
250 -2.5db
315 +3 db
400 +3db
630 -6db
800 -6 db
1.6K +3 db
2K +3db
2.5K +3db
3.15K -3.5db
4K -6db
5K +5 db
8K -4 db
10K -4 db
So, not much changed with boosting or cutting the gain at the xover. The ones that got cut the most, still were cut about the same. The ones boosted were still boosted about the same (I have 2 other test and they are all boosted in the +3 range). Only the 5K band was changed in the end by boosting it 2db more (from +3 to +5).
So, is this expected? What should I make of this? Advice? Concerns?
sine143
Re: RTA'd my speakers, here's what I got. What does it mean
#2 Post by sine143 »
dont trust the DBX mic above about... 4khz. wildly inconsistent between units imo.
Your measurment technique is not conventional, but for the sake of a "quick and dirty" test it does the job.
notes:
Dont boost 50hz (below crossover point, pointless)
heres a pic of my current eq settings for the ot i believe.
4x Otop12 d2512 loaded
2x AT (1 mcm, 1 gto 804)
1x bastard XF208
#3 Post by Grant Bunter »
Dan,
Was this outdoors?
And a minimum of 50 feet of clearance all around, from the cabs, with no obstructions/fences/buildings?
#4 Post by Radian »
Dan56 wrote:50K +3 db
125K +3db
160K +3 db
250K -2.5db
3.15K +3 db
4K +3db
630K -6db
800K -6 db
Calibrating the sonar? :confused:
Dan56
#5 Post by Dan56 »
sine143 wrote:dont trust the DBX mic above about... 4khz. wildly inconsistent between units imo.
Your measurement technique is not conventional, but for the sake of a "quick and dirty" test it does the job.
notes:
Any boost or cut I posted is what the Driverack did on its own. Your eq curve kind of mimic's mine. That 4K seems to be an issue. When I had first checked the system in our practice room with my other sound meter the 4K needed to be cut 6db based on that too. So, maybe what I have is what would be expected for these speakers.
How would you have done this initial RTA? What mic?
Dan56
#6 Post by Dan56 »
Grant Bunter wrote:Dan,
Was this outdoors?
Yes it was. Had at least 100' in front of the speakers and 50' on the sides.
Dan56
#7 Post by Dan56 »
125K +3db
160K +3 db
250K -2.5db
3.15K +3 db
4K +3db
630K -6db
800K -6 db
Thank you Radian for pointing out my posting error. This is what I get for being in a hurry while helping my brother inlaw do his front brakes. I just corrected the numbers.
But, here they are again.
50K +3 db
125 +3db
160 +3 db
250 -2.5db
315 +3 db
400 +3db
630 -6db
800 -6 db
1.6K +3 db
2K +3db
2.5K +3db
3.15K -3.5db
4K -6db
5K +5 db
8K -4 db
10K -4 db
#8 Post by Radian »
Just a little sound guy ribbing. :lol:
Knew what you meant to type. 8)
Dan56
#9 Post by Dan56 »
Radian wrote:Just a little sound guy ribbing. :lol:
I got a laugh out of it. But, I had not noticed until you posted.
Dan56
#10 Post by Dan56 »
Sine's response got me thinking so I went looking for more info on reference mics and came up with this article by Real Traps.
http://realtraps.com/art_microphones.htm
This was a comparison of 11 mics ranging from $40 to a Josephson with a Microtech Gefell capsul. The boundaries of the test are:
Note that this test did not attempt to evaluate anything other than raw frequency response. We didn't measure distortion, off-axis response, maximum SPL capability, build quality, or residual noise. Nor did we record any musical instruments. Our only goal was to determine the suitability of these microphones for measuring in-room loudspeaker response.
And: Since this is not a true anechoic chamber you will see some influence from the room, especially at low frequencies. So even if a particular microphone is perfectly flat, its response will not appear flat in the graphs due to the room. However, the relative responses are valid, letting you compare how closely the inexpensive microphones match the expensive calibrated models that are known to be highly accurate.
It is interesting that they all start to dip a bit after 3k and more so after 7K. But they are all within a few db. Only the Radio Shack meters get stupid after about 1.5K.
So, for our purposes the DBX and such are adequate.
The other thing Sine noted was that my setup was not conventional. So what do others do for setting up their initial sound test? I'm thinking I'm going to retest leaving the xover gain at zero and leave that as the base setting. Should it matter where the xovers are set as to the system being flat?
Dan56
#11 Post by Dan56 »
I got to redo my tuning today. I used the same setup (x overs at zero gain) and then ran it for Flat, Band and Speech. I recorded the db changes for each frequency and then charted them in a spreadsheet and graphed. Here is what I got.
Interesting where the changes are with each tuning type vs how similar.
Also, a bit off topic, but I just picked up an Allen & Heath GL2400 24 channel board. So system is getting more pro a little at a time.
byacey
#12 Post by byacey »
I think you'll really like the GL2400. I got a GL2400/32, it's a nice compact, well built board. It sure beats the Yamaha PM3000 32 in the convenience and weight department.
T48s
WH8s
SX212
leamy_f
#13 Post by leamy_f »
Dan56 wrote:I got to redo my tuning today. I used the same setup (x overs at zero gain) and then ran it for Flat, Band and Speech. I recorded the db changes for each frequency and then charted them in a spreadsheet and graphed. Here is what I got.
I use the same mixer from time to time and imho this board has one of the best sounding eq sections bar none, you won't be disappointed...regards
byacey
#14 Post by byacey »
I think I would forget about the various "tunings" and just set it flat as possible and then adjust it to taste from there. Full response more or less flat will sound good for music and speech.
T48s
WH8s
SX212
Dan56
#15 Post by Dan56 »
byacey wrote:I think I would forget about the various "tunings" and just set it flat as possible and then adjust it to taste from there. Full response more or less flat will sound good for music and speech.
Yes, that is what I was thinking. But, I just wanted to see what it did and how it sounded. Running a song via the computer, flat actually sounds best. I'll hear the band tonight with it.
