I have been building the FX 410. I decided to make it a bit wider than the plans so that my Ampeg V4 would not look to big sitting on it. I debated with my self as to running the baffles to the full width or following Grant's suggestion of using a filler strip. I crunched the numbers and even did the lay up for the full width baffle, but then went with the fill strip. The reason for the final choice was to keep the speakers set within the cab per the design. If I went with the full width baffle, then the speakers would have been set a bit deeper in the box.
The first picture is my sliding table. I followed the suggestion of ripping some strips from the 3/4 ply for the runners and they ended up too narrow. Unfortunately, I had attached them before I checked.
So, I'm showing my solution. I used some 8 - 32 brass machine screws as a gibb like system on one side. When I had that adjusted well, I laminated some sticks to the other runner and then sanded them until I was satisfied with the fit.
- 1 Sliding Table.jpg (136.52 KiB) Viewed 3042 times
A couple other decisions. I went with the square box front instead of the angled and it's a closed back. It's what I like. I've never had a desire to have an open back cab.
I rabbeted the joints. Here is the trial fit.
- 2 three side trial fit.jpg (139.31 KiB) Viewed 3042 times
Here is the box glued up. Front and Back.
- 3 Box glued up.jpg (138.15 KiB) Viewed 3042 times
- 4 Back.jpg (139.56 KiB) Viewed 3042 times
Fitting the handles.
- 5 Fitting handle.jpg (140.95 KiB) Viewed 3042 times
More in the next posting.
