Favorite round-over for cabinet edges?
I have a T39 about ready to be made smooth - so far I have 5/16" (great for handles) 3/8" and 1/2" radius round-over bits. What works best on the outside of the cabinet?
1 Omni-15 Tall Boy
2 DR250s
2 Titan 39s
1 Omni-15 Tall Boy
2 DR250s
2 Titan 39s
Re: Favorite round-over for cabinet edges?
I like 3/8 the most thus far. much more than 1/2 at least.
Just make sure you get corners that fit!
4x Otop12 d2512 loaded
2x AT (1 mcm, 1 gto 804)
1x bastard XF208
1x bastard XF208
morticiaskeeper
I use a 6.3mm bit. Roughly 1/4".
3/8 has worked great on mine.
I found, for the T39's, using larger plastic lock tab type corner protectors, you need at least 1/2" there (at the tip of the corner, or the protectors sit proud).
Other than that, the rest of the edges on my cabs are 3/8" as well...
The standard radius for corner protectors is 3/8".
I've used 1/2" on all my cabs so far with good results. I use the metal corners and some have to be coaxed into place, but they still look good. My poor Harbour Freight bit is getting wore out from hitting brad nails. Oh well.
I have found "small" corner protectors at Blue Aran over here that are for 1/2" roundovers. As Bill says though, usually they are 3/8".Bill Fitzmaurice wrote:The standard radius for corner protectors is 3/8".
Thanks for all of the advice. I went with the 3/8" bit, and the speakerhardware corners that came with my kit fit perfectly. It also allowed me to round over the sides where there was nothing but the side along the horn mouth. Pictures in my build thread.
1 Omni-15 Tall Boy
2 DR250s
2 Titan 39s
1 Omni-15 Tall Boy
2 DR250s
2 Titan 39s
