Re: XF212
#16 Post by AntonZ »
Thanks, that looks good albeit a bit pricey over here (about 3x US price).
Re: XF212
#17 Post by LelandCrooks »
Ah, forgot you were over the pond. Try Fane.
Re: XF212
#18 Post by AntonZ »
Yes, it is about €130 here. Each, so that would be €260 for a pair.
Charles Jenkinson
Re: XF212
#19 Post by Charles Jenkinson »
Is there a typical radius folks put on frame edges when fitting this mesh? I haven't got any appreciable radius on yet, and I'm thinking it needs something.
2xT30
Re: XF212
#20 Post by DJPhatman »
Is that frame 12mm thick? Sorry if I missed it.
Charles Jenkinson
Re: XF212
#21 Post by Charles Jenkinson »
Yes, its 12mm thick DJ. The mesh is the stuff from Leland. Anyway, i realised I probably didn't really need an engineering poll on this, so just planed something around an 1/8" radius or a bit less and that'll keep the tension required to bend it round an otherwise sharp corner down a bit, and prevent relaxation at a later date.
2xT30
Re: XF212
#22 Post by DJPhatman »
Charles Jenkinson wrote:Yes, its 12mm thick DJ. The mesh is the stuff from Leland. Anyway, i realised I probably didn't really need an engineering poll on this, so just planed something around an 1/8" radius or a bit less and that'll keep the tension required to bend it round an otherwise sharp corner down a bit, and prevent relaxation at a later date.
Then 1/4" or 6mm round over. Stretch it over, then staple it down. If it loosens, pull the staples on one side and pull tight again.
jimbo7
Re: XF212
#23 Post by jimbo7 »
This doesn't always work, but I like to take a dowel rod and wrap the fabric around a few times then stretch it over and staple. This helps keep the fabric square to the grill so it's not mis-shapen or distorted.
Charles Jenkinson
Re: XF212
#24 Post by Charles Jenkinson »
Ok, thanks guys. The front frame with mesh is looking more and more like it is going to be last thing finished, but that makes some sense, of course.
Here's the foam fitting. The back door needs a couple bare patches where speaker magnets are close - should've got a picture of it - may still be able to, but when you lay a speaker in and look in the back along the door plane, its obvious. Also Spent 15 minutes looking for a butterfly catch screw, which I'd lost, but knew had seen somewhere, - they're the worst lost screws right, arghh! :-)
2xT30
Re: XF212
#25 Post by LelandCrooks »
Nice, nice.
88h88
Re: XF212
#26 Post by 88h88 »
Really like the colour of that.
Re: XF212
#27 Post by Tom Smit »
It looks pro, Charles.
Charles Jenkinson
Re: XF212
#28 Post by Charles Jenkinson »
Thanks Gents. I'm not going as slow as i can to keep anyone in suspense, but whilst i was on a roll i have meshed the frame and leaned it in place for a quick picture. ...Sheesh, I'm not that far off needing to find someone who can play for a video shoot ont th'eye pad.
2xT30
Re: XF212
#29 Post by DJPhatman »
Charles Jenkinson wrote:...Sheesh, I'm not that far off needing to find someone who can play for a video shoot ont th'eye pad.
Not quite, mate. You need to get to getting on with the psychedelic patterns on top of that purple haze! :P :lol: :mrgreen: :ugeek: :horse: :lol:
Hackomatic
Re: XF212
#30 Post by Hackomatic »
:shock:
Paranoia: noun
A serious mental illness resulting from construction prowess and the inevitable belief that other people might touch, fondle or otherwise damage the finish of your speaker cabinets because they are too perfect.
Dave H
