Thank you all for your responses. I got them made up and running.
My setup consists of the following:
2 T30's Delta 12LFA loaded
2 Behringer eurolive 2015's
Behringer XENYZ 1002B mixer
Drive Rack Pro PX.
Crown XTI 1002 Tops
Behringer EP2500 Subs
I have the subs x at 40hz-100 and the tops from 100hz on up.
Is this setup sound about right?
Also, I have read the section on the limiter, but I am confused on how to limit voltage. Do I set that during the Pink noise part of the setup wizard that sez raise volume to performance level?
Should I post this question in a new post?
Thanks again,
Oscar
Berhinger DC3400 ???
Re: Berhinger DC3400 ???
Disconnect cabs from amps. Run 60 hz, measure volts coming from sub amp when desk is at unity (no more can come out of desk). Adjust limiter to bring voltage down to the limit for the Delta12LFA.
For the tops, one can usually hear the distortion.
Thanks for the reply Tom,Tom Smit wrote:Disconnect cabs from amps. Run 60 hz, measure volts coming from sub amp when desk is at unity (no more can come out of desk). Adjust limiter to bring voltage down to the limit for the Delta12LFA.
Not sure what you mean by "unity". Do you mean mixer channel and master at full volume, past 0db scale?
What should the voltage be. 40V?
Thanks
Oscar
Many Thanks, Will do
Fixed that for you Tom...Tom Smit wrote:Disconnect cabs from amps. Run 60 hz sine wave, measure volts coming from sub amp when desk is at unity (no more can come out of desk). Adjust limiter to bring voltage down to the limit for the Delta12LFA.
djtrumptight
I thought T-30's could be high passed lower,like 35 hz ?
2 Autotuba's MCM 55 2421
8 T48's 24"wide 3015 LF
2 SLA HT systems
1 Table Tuba Dayton DCS 255-4
2 T 39's 20" wide 3012 LF
1 T-18 13" wide MCM 55 2421
2 SLA Pro's
2 SLA HT systems
2 SLA Pro's
You're right, 35hz.djtrumptight wrote:I thought T-30's could be high passed lower,like 35 hz ?
