DIY USB impedance/capacitor/inductor measurement tool
AlessandroAU
#1 Post by AlessandroAU »
I wanted to expand my toolset and be able to take impedance measurements. Of course there is the commercial option http://www.parts-express.com/dayton-aud ... m--390-806, but after shipping to AUS I'd be looking at $150 or so. I did some reading and come across this nifty program. http://www.speakerworkshop.com it seemed very easy to use with only a few external components needed http://www.claudionegro.com (find the "cables" page). So I built the test jig and took some measurements and it seemed to work ok, at least for a while. Eventually I started getting weird results, I chalked it down to my laptop's internal soundcard not being up to the task.
I decided to build a dedicated USB solution. I did more research and found the Behringer: U-CONTROL UCA202 a very decent and inexpensive ($30) USB sound interface. I preformed the mods listed here http://nwavguy.blogspot.com.au/2011/03/ ... endac.html to improve the low end response. This was probably the hardest part as it involved some SMD soldering. Then I added some switches and resistors to make calibration easier and put the whole thing in a box. I used some precision 0.1% resistors from vishay. Depending on components used the total cost could be below $50, not bad for a device that will take impedance plots, measure resistors, capacitors, inductors and estimate T/S parameters!
I've attached some pics and an impedance plot measurement of my table tuba. Can someone tell me if this is what the plot should look like?
Edit: Spelling
Impedance Plot of Table Tuba
Yes its messy, but it works :)
I've preserved all the inputs and outputs of the UCA202 so it can still be used normally.
Front Panel
Front Panel
It also doubles as a headphone amplifier
J_Dunavin
Re: DIY USB impedance/capacitor/inductor measurement tool
#2 Post by J_Dunavin »
Very cool! :clap:
#3 Post by LelandCrooks »
Looks about right. Nice.
#4 Post by Bill Fitzmaurice »
AlessandroAU wrote: I've attached some pics and an impedance plot measurement of my table tuba. Can someone tell me if this is what the plot should look like?
+1.
sine143
#5 Post by sine143 »
whats your table tuba loaded with?
4x Otop12 d2512 loaded
2x AT (1 mcm, 1 gto 804)
1x bastard XF208
AlessandroAU
#6 Post by AlessandroAU »
sine143 wrote:whats your table tuba loaded with?
I've got it loaded with a DCS205-4
