Another silly idea
jimbo7
Another silly idea
#1 Post by jimbo7 »
While reading up on THT's I was thinking "Since corner loading yields the best results for a folded horn, could you design the mouth at the corner of the sub so it can sit parallel with the corner instead of at an angle?"
It'll require a total redesign, but would it work?
Re: Another silly idea
#2 Post by Grant Bunter »
Well, the way I see it, why does the cab have to be angled?
If it's square into the corner, equidistant from both walls, it will still be corner loaded no?
#3 Post by Bill Fitzmaurice »
Grant Bunter wrote:Well, the way I see it, why does the cab have to be angled?
Corner loading occurs when the mouth is less than 1/4 wavelength from the corner, irrespective of the cabinet orientation. An angled orientation will squeeze a couple more dB and Hz, which can be useful in pro sound. With a THT in a home the last thing you need to be concerned about is a couple more dB and Hz.
jimbo7
#4 Post by jimbo7 »
The cab would be square to the wall corners, but the mouth of the cab would aim right where the 2 walls converge.
This idea doesn't pertain to just the THT, although most living rooms have their furniture at right angles or parallel to walls.
escapemcp
#5 Post by escapemcp »
Do you mean something like this???:
(brown is sub, dotted line is end of normal sub (so triangley bit is the new part) and black is the walls).
jimbo7
#6 Post by jimbo7 »
Like this:
sine143
#7 Post by sine143 »
the hardest part of horn design is actually folding it into a box ;p
your suggestion would make folding more difficult.
4x Otop12 d2512 loaded
2x AT (1 mcm, 1 gto 804)
1x bastard XF208
jimbo7
#8 Post by jimbo7 »
Someone once said "anything that's worth doing is usually difficult", or something like that. What was his name?.... Oh yeah, Jesus.
sine143
#9 Post by sine143 »
1x bastard XF208
Ryan A
#10 Post by Ryan A »
sine143 wrote:the hardest part of horn design is actually folding it into a box ;p
Here's what I would do *brainstorming*...two boxes in one.
In order to get a full 7-10 foot long horn the box would have to be around 36" X 36" though. It would probably use 8" drivers or 10" at the largest.
It goes without saying its a lot easier just to make due with the designs we have already. Its questionable how much of a difference it would really make too.
BrentEvans
#11 Post by BrentEvans »
There's no way the horn path on that would be long enough.
If you really just want something that looks square, build two of whichever of Bill's designs fit, put a Vplate on top, and false sides around the front to square it up. It will work quite well and look nice too. Or, just square up a single cab to the walls... there won't be much difference at all.
Ryan A
#12 Post by Ryan A »
BrentEvans wrote:There's no way the horn path on that would be long enough.
Umm, actually it would. If you really need THT extension it could be built larger.]
I personally wouldn't do it as it takes up too much floor space.
sine143
#13 Post by sine143 »
this thread is already off topic as per site rules, but ryan your design would be better suited to a tapped horn with 4x 8 inch drivers (or hell, even 4x anarchy 6s. you could fit a lot more horn path in there without the rear chamber, and a small mouth is NBD with a tapped horn.
1x bastard XF208
jimbo7
#14 Post by jimbo7 »
I think I put a bug in Ryan and Brent's ear. The might turn into a full-fledged debate.
Ryan A
#15 Post by Ryan A »
There's nothing to be debated...it would work and work well in concept.
Its not my place here to design horns though so all I can do is brainstorm with you.
As Bill has already said there's not much to be gained anyway.
