XF210 build in the UK
Re: XF210 build in the UK
How did you manage to bend the steel corners on the top front edge? Brute force & a big hammer, or some other, more refined method? I've been thinking this conundrum over for several weeks, as I plan my 210 build. Having built (& heavily used) the 212, I've decided corners are a must. The angled front is the fly in the ointment...
For my 210 (actually a 2x8) i just made the corners straight faced (about an inch tall)
4x Otop12 d2512 loaded
2x AT (1 mcm, 1 gto 804)
1x bastard XF208
1x bastard XF208
More like gentle force with a small hammer!   I aligned the corner with one edge and fixed it with the first screw.   I then tapped the corner into shape with a small ball pein hammer, protecting the metal from dings with a bit of scrap ply.   Once it was pretty much aligned with the second edge I fitted the second screw to pull it into its final position.   I wouldn't claim they are perfect, but I've seen shop bought cabs which were no better.
									Built: XF210
Building: None
Considering: Jack 10 Lites and Wedgehorn 6s
						Building: None
+1Oxonjohn wrote:More like gentle force with a small hammer! I aligned the corner with one edge and fixed it with the first screw. I then tapped the corner into shape with a small ball pein hammer, protecting the metal from dings with a bit of scrap ply. Once it was pretty much aligned with the second edge I fitted the second screw to pull it into its final position. I wouldn't claim they are perfect, but I've seen shop bought cabs which were no better.
I use a plastic deadblow hammer.
- Charles Jenkinson
I haven't read of a driver break in routine for the XF projects, but there must be a rough formula that could be used to figure out a driver dependent voltage/ frequency....? Ain't it white noise for guitar drivers...? Not exactly inaudible though, like a nice 25Hz.
2xT30
						2xT30
The generally accepted way for breaking in guitar drivers is just to play them, loud and long.   There are a couple of alternative shortcuts, but why would I use them when I've been given an excuse!
									Built: XF210
Building: None
						Building: None
...because enjoyment would begin right away.Oxonjohn wrote:The generally accepted way for breaking in guitar drivers is just to play them, loud and long. There are a couple of alternative shortcuts, but why would I use them when I've been given an excuse!
 It wouldn't take much. Run the driver out of the cab hard enough, without hitting the limits, to get it moving good.
  It wouldn't take much. Run the driver out of the cab hard enough, without hitting the limits, to get it moving good.TomS
